Mini/MINI BUILDS Showcase your Build Talents.
2006 R52 Manual Transmission.
Old Aug 13, 2019 | 08:30 AM
rujero's Avatar
rujero
Known problems so far:
  • Fuel gauge not registering: Half a tank of new premium fuel and a new fuel pump are in place, but the MINI doesn't seem to realize it has fuel in it, with a flat fuel gauge. Attempts to reset the ECU ran into a problem when using the amazing guide by shorty_du_op. Specifically I get stuck at step #5 when I get into the system but am supposed to "scroll through" to choose the next option, but how do you scroll with just one button to push? When I push the button at that step it seems to revert back to simple odometer function.
  • No spark in 3 out of 4 plugs: Spraying starter fluid into the manifold had me hearing the engine trying to turn over. suggesting a fuel problem, however after checking spark plugs it seems like the engine was only working with one functioning spark plug.
  • The car sat for about a 12 months with the stick in neutral and I cannot shift it into any gear position. Seems as though the linkage is frozen.
  • MORE SOON
Additional items on the agenda:
  • All four rotors will be replaced
  • New wiper blades
  • The center brake light lens is missing with exposed LEDs
  • The rear tail lights stay on after turning off the car with no obvious reason why
  • New oil and filter
  • New air intake filter
  • New cabin air filter
  • New tires: the car was purchased with 215/45/R17 tires on it, but every source I can find suggests the stock tire is 205/45/R17. Unknown if the previous owner was simply trying to get a larger contact patch on the ground, but I will go back to recommended tires.
Old Aug 14, 2019 | 11:45 AM
rhenry01's Avatar
rhenry01
You've got your work cut out for you but as you tick the boxes on your to-do list it is quite rewarding. Good luck.
Old Aug 18, 2019 | 05:23 AM
Cenla Mini's Avatar
Cenla Mini
Just a couple of other things to consider.
- GEN 1 Mini's typically need thermostat's replaced more often than other cars. You should replace the entire housing. Also check the reservoir for evidence of a leak.
- Consider doing a compression test on a warm engine. If your test is not consistent across cylinder's try adding a teaspoon of oil and perform a wet test for further diagnostics.
Also...go through the Stock Problems/Issues here on NAM.
Have fun and keep posting updates. There are a lot of folks here who have been where you are who can and usually will offer pointers.
Old Aug 18, 2019 | 08:27 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sounds like a bunch of little things. Good luck and hope we can help with any parts you need.
rujero
Aug 15, 2019 09:08 PM
BMV_1
R60/R61 Stock Problems/Issues
Jul 19, 2019 08:25 PM
BadgeFTW
Sep 14, 2015 03:49 PM
drew1969
Feb 7, 2014 05:55 AM
Ballsy
Jan 29, 2014 05:20 AM
