Vibration
Old Aug 12, 2019 | 09:03 AM
CasoR53S's Avatar
CasoR53S
Vibration
Hey guys,
I am a new owner 2005 S. Had it for a few weeks and have noticed a vibration around 65-75mph but only when accelerating. Is there an easy way to tell if the Hydraulic motor mount is bad? I though it may the tires but it is only when i am accelerating so I was leaning towards motor mounts. The hydraulic motor looks okay( no fluid around it, still has some "bounce" to it.) Not sure where to start.
Thanks guys
Old Aug 12, 2019 | 09:22 AM
tej98's Avatar
tej98
Originally Posted by CasoR53S
Hey guys,
Thanks guys
I've got a similar issue, also happens when accelerating between 2k to 3k rpm. I know my engine mounts are worn so I'll be changing them soon.
Also I noticed my axle boots are torn and seem to have thrown grease all over the place so I'm guessing they could be a potential problem..
Can you see fluid leaking out of the engine mount you see when you open the hood? Mine clearly has been leaking for a while (just bought car)
Old Aug 13, 2019 | 10:35 AM
JABowders's Avatar
JABowders
Veteran: Army
Congrats on the Purchase a your smile machine.
Since it is a 2005 and I ALWAYS assume the previous owner never did maintenance ...
Time to replace ALL the rubber bushings (suspension, and don't forget the strut tower mounts), and mounts ... a great time to double check the ball joints as well, and if your axle boots are bad I would replace the axles ... sure you could just replace the boot, but, chances are the knuckle joints are worn due to lack of proper grease, so in the long run you are better off going new over replacing the boots.
I was telling some just the other day, How I just replaced the leaf spring bushing on my MG Midget, then I remembered I did but it was really 15 years ago, time to reorder them ($16.00 for all of them)
Best of luck.
Motor On!
Old Aug 13, 2019 | 11:39 AM
CasoR53S's Avatar
CasoR53S
Best of luck.
Motor On!
All the bushings i look at underneath looked almost new. I was planning on slowly replacing them anyway, this just may speed up my process.
Old Aug 13, 2019 | 02:38 PM
colinmini's Avatar
colinmini
Sounds like what I am experiencing......I have a bad cv joint(after 165,000 miles. Go with a better brand cv half shaft or axles (oem or GKN’s) the el cheapo’s have spotty quality.
Old Aug 26, 2019 | 02:16 PM
CasoR53S's Avatar
CasoR53S
Update: Got it up on stands and looked at the wheel end. After being able to just push the struts up by hand i though maybe that was the culprit. Replaced those and it drives a lot better. Still has a little vibration. Does anyone have a picture of what a new or at least good hydraulic motor mount looks like installed so i can compare to mine?
Old Aug 26, 2019 | 03:21 PM
Andy_S's Avatar
Andy_S
See my pics here.
https://www.northamericanmotoring.co...ml#post4451183
Old Aug 26, 2019 | 08:15 PM
CasoR53S's Avatar
CasoR53S
Originally Posted by Andy_S
Awesome. Thank you for that. Mine definitely needs replacing. I may just change all of them. Would that cause vibration at say 70MPH?
Old Aug 27, 2019 | 05:14 AM
colinmini's Avatar
colinmini
How do the cv joints’s feel? Any slop? Just changed mine, what a difference! Smooth as ice!
Old Aug 27, 2019 | 06:46 AM
Andy_S's Avatar
Andy_S
I never noticed any vibration, I just replaced it because it had obviously leaked fluid everywhere.
BeakyBuzzard
Sep 4, 2017 03:29 PM
frankiev
Dec 23, 2016 04:50 AM
sarom058
Apr 5, 2016 11:34 AM
mcart5
Mar 3, 2016 09:31 AM
Jesse Mattingly
Oct 31, 2015 09:43 PM
