2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Moonroof initialization process?
Old Jul 23, 2019 | 08:57 AM
creep's Avatar
creep
Does anybody know the moonroof initialization process? Mine was stuck in the tilted position so I dropped it off at the dealer to fix. They texted and stated they just re-initialized it.
I was googling last night on initialization processes and found some instructions for older MIINIs and for current BMWs. None of them worked for me...
I tried:
1) Holding the switch for 30 seconds (Tried both directions)
2) Holding the switch for 30 seconds in one direction, then switching to the other direction for another 30 seconds
3) I tried both methods above with the car completely on (engine running) and just on (no engine running)
Old Jul 23, 2019 | 09:21 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.newtis.info/tisv2/a/en/f...oof/1VnY0wY6rR
Old Jul 23, 2019 | 11:56 AM
creep's Avatar
creep
Thank you for the link.
If I'm reading this correctly:
"Operate and hold down the switch in the first of the two possible positions towards "Close"
Then I may have messed up. I pushed the switch all the way to the end (two clicks). I'll try this method if my roof gets stuck again.
Old Jul 25, 2019 | 09:16 PM
creep's Avatar
creep
Wow, I just started looking at the URL you provided and realized it can provide the entire repair manual.
Thanks!!
Old Jul 25, 2019 | 10:09 PM
Minnie.the.Moocher
I'm guessing some day that this goes away as a freebie. I started to download and save info for my car and finally gave up and lost interest in doing so. Figured by the time I finished I'd probably have a different car.
Old Aug 22, 2020 | 06:16 PM
creep's Avatar
creep
Happened again. Moonroof won't close and is stuck in the tilt position. I tried the initialization process outlined in the link above, but no luck.
Anybody figure out how to do this? If not I guess I'll have to take it all the way back to the dealer on Monday. :(
creep
Oct 24, 2022 07:55 AM
rottentomato
May 30, 2014 03:28 PM
Natty
Jul 15, 2004 07:37 AM
danbanger
Jun 21, 2004 12:00 PM
otto
Aug 3, 2002 09:00 AM
