Android "Torque" app for gauges via OBD2. PIDs?
Old Jul 21, 2019 | 10:36 AM
RangerGress's Avatar
RangerGress
Is there a list of PIDs around to allow Torque to pull more data from the OBD2 stream? Would be nice to have oil temp and air/fuel ratio. I see a number of Gen2 conversations re. the Torque app and PIDs, but not much for the R53.
Old Jul 21, 2019 | 02:26 PM
deepgrey's Avatar
deepgrey
I can’t help you with PIDs or Torque, but I can tell you that you can’t monitor oil temp or AFR via OBD2. The R53 doesn’t have an oil temp sender or a wide band O2 sensor.
Old Jul 21, 2019 | 05:42 PM
RangerGress
Well, that hoses my top 2. Thanks for the info.
Old Jul 23, 2019 | 08:25 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
Why would you think you can get AFR? Mini's ECU is just as foggy when it comes to AFR. Why, it has a narrow band O2 sensor, and the control system is either Bang-bang hunting control, or dumb lookup tables for open loop, which applies to 99.5% of my Mini's application.
Old Jul 23, 2019 | 08:42 AM
RangerGress
Well, because I don't know what I'm doing. I know 80's BMW engines pretty well, and they started using narrow band O2 sensors with Motronic 1.0 in '84(?). But outside of those engines, I'm pretty helpless. I figured that engine management had to start using wideband O2 sensors eventually, I just don't know when that sort of thing began.
miniuy
Oct 7, 2016 12:09 PM
flintdragon
Electrical
47
Nov 1, 2014 09:46 AM
m3sparky
Sep 30, 2014 10:09 AM
scoopy
Jun 21, 2012 12:06 PM
mike.cal
Feb 25, 2011 10:59 AM
