FS:: JCW supercharger // LSD // Coilovers + Camber Plates // Tail-lights
Price: $1
Location (Region): SoCal
SOLD - OEM Eaton M45 supercharger off 2006 JCW (~75K miles); these should have the Teflon-coated rotors if memory serves (?). Includes the JCW pulley attached, which I think is around an 11% reduction vs. standard MCS. Was working OK when removed to upgrade to a TVS900, but keep in mind it does have around 75K miles, so it may be getting a little tired... Supercharger oil service was done ~2 years ago. Note the supercharger was functioning and there were no strange noises or clicking sounds prior to removal.
$300 - OEM Factory LSD off 2006 JCW (~75K miles). Was working fine when removed to upgrade to an OS Giken LSD.
SOLD - ST Coilovers + SPC/Eibach adjustable camber plates. These were purchased in 2011, have about 30K miles on them, and have been sitting in my garage the last year or two. I was told one or both of the rear shocks was leaking, so ended up replacing them with some higher-end coilovers. Camber plates seemed to be fine when removed. Not interested to split the camber plates from the coilovers as I don't have the right tools to remove them.
$50 - OEM tail-lights (both left + right) off 2006 JCW. They have some haziness -- do a search and you'll find this is a not uncommon on 05/06 MCS. They work fine, but one brake light bulb is burned out. I finally decided to just replace them vs. replacing the bulbs. Might be good if you don't mind the haziness, need some replacement parts, and/or are looking for something to play with blacking out/etc.
Supercharger:
Factory LSD:
ST Coilovers + SPC/Eibach camber plates:
Tail-Lights:
Dr. Spade
Jul 23, 2019 04:56 PM
Mjimport
Feb 10, 2013 07:55 PM
Chilipeppa03
Suspension
Dec 6, 2007 07:59 PM
ej
Suspension
26
Dec 29, 2006 08:16 PM
