R56 Help, damage from mechanic
Old Jul 7, 2019 | 06:12 PM
souljourner's Avatar
souljourner
Took my 2009 R56 JCW mini to a local quick oil change shop due to being too busy at work. Regretting this very much.
Supposed to be a quick job but I had to wait an hour and half for them to attempt to replace the oil filter. When I got home I found this cracked air charge pipe and broken blow-by-recirc from valve cover to intake runners.
I’m not going to bother going back to argue but would love some help getting part numbers so I can replace these!
if anyone know what the part numbers for these are and where I can buy them, this would be much appreciated!
John (San Mateo, CA)
Intake piping between MAF and turbo inlet
recirc plastic T's
Old Jul 7, 2019 | 08:36 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
look here realoem.com
Old Jul 7, 2019 | 09:18 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
That's unfortunate, but honestly those hoses commonly break as the plastic drys out and will be brittle. So anyone that just touches it will make it fall apart.
Here is the new one
https://www.waymotorworks.com/jcw-tu...5-r56-r57.html
Old Jul 8, 2019 | 08:22 AM
Yupetc's Avatar
Yupetc
WMW is right, the rubber components do get brittle due to repeated heat cycles and therefore oxidation occurs and loses the elasticity properties. They crack easily after a certain time/mileage. It could possibly have been avoided if they first properly remove the intake tube, but I guess they didn't, and instead, they probably jammed their 24mm socket head onto the filter cap and try to undo it from there. Could partially be their fault, but mostly because the rubber has become too brittle for whoever touches it will probably just break it the same.
Old Jul 15, 2019 | 07:49 AM
Yikes, yep heat cycles and it gets brittle.
That intake manifold looks like the cold climate version which is now nla. You would have to switch over to the original, or fit the one you have with some universal hardware.
https://www.northamericanmotoring.co...e-version.html
at7815
May 6, 2009 11:02 AM
at7815
Detailing 101
May 4, 2009 08:04 AM
Pitterpop
Jun 6, 2008 09:28 PM
Methman
May 4, 2007 11:47 PM
waddeym
17
Apr 5, 2006 10:36 AM
