2013 R56 Oil Eater
Old Jun 18, 2019 | 03:19 PM
525iEnjoy's Avatar
525iEnjoy
2013 R56 Oil Eater
Hi Everyone
I have a 2013 Base Hatch. Owned since 5,000 miles, Car has 56,000miles currently. In between the last 2 service intervals I have had to add 5 quarts of oil. I have never had to add oil up until this point. I have no oil leaks, my PCV isn't clogged, I had a leak down test no issues, I had my cylinders and piston tops inspected for carbon and found little to no evidence. I have read, posts, threads, websites and watched videos and no one has any clue on why these cars are doing this.
From my diagnosis I have feeling that these engines oil rings now older cant keep up and are causing excessive blow by thru the PCV. That and possibly the engine is so under powered that keeping its RPMs above 3100 for hours and days on end might be a contributing factor. Which means Bad Design?
Has anyone here defeated this issue? Thoughts?
Old Jun 18, 2019 | 04:43 PM
MiniToBe's Avatar
MiniToBe
how often are you doing the oil changes?
Old Jun 18, 2019 | 09:59 PM
renchjeep's Avatar
renchjeep
I have noticed that my wife's 2013 Justa Convertible auto with 70k miles uses significantly more oil than my 2011 R56S manual which has 105k miles on it. My 2011 uses about a quart of Mobil1 0w40 between 5k oil changes, while her 2013 uses more than 2 quarts of Mobil1 5w30 in the same interval. Neither one leaks a drop.
Old Jun 20, 2019 | 12:11 PM
525iEnjoy's Avatar
525iEnjoy
Every 5K miles. I try to keep 3 changes per year
Old Jun 20, 2019 | 07:55 PM
dmrispoli's Avatar
dmrispoli
3100 rpm? I dont drive my wifes 2011 all that often, but I glance at the tach and when it is humming along at 70mph it doesnt even come close to 3k.
that said, hers only started eating oil in the last year or so and I was told when the car went in for a separate warranty issue that it is something they do. that, and the timing chain tensioners can leak without dripping oil under the car which I highly suggest changing out (just for general maintenance).
Old Aug 8, 2019 | 09:28 AM
525iEnjoy's Avatar
525iEnjoy
We had great progress with driver mod in keeping the revs down, but it still ate oil. Oh well. Its been sold. We couldn't justify doing a short block or equivalent .This car was almost paid off to.Good luck all
Old Aug 15, 2019 | 08:25 AM
patpatpat's Avatar
patpatpat
I had oil consumption issues with Mobil 1 - about a quart every 1k miles. Switched to Castrol A3/B4 0w40 and no oil lost until 4000 miles in and about 0.5 quart for every 1k miles after that.
YMMV
ptguy0618
Sep 10, 2017 06:46 PM
mattkosem
Oct 17, 2014 07:00 PM
TVPostSound
Aug 4, 2014 11:39 PM
RoyalCooper
Mar 27, 2013 05:14 PM
TimG517
Jun 18, 2012 09:55 AM
