R52 engine keeps stalling when idle or stopped
Old Jun 8, 2019 | 08:53 PM
iceman_jonny's Avatar
iceman_jonny
so when i start my 2005 r52 after its been off for a couple hours it idles at about 1200
as soon as i start driving, whenever i hit the clutch and keep it depressed for too long it stalls
if i switch gears fast enough itll keep going but has trouble going uphill
id say it stalls after going under 800rpm
ive had misfires for a while and changing the spark plugs, spark plug wires, and the ignition coils havent helped
i was reading that it may be the fuel injectors are bad
i wanted to get some more opinions on what it could be
thanks in advance!
Old Jun 11, 2019 | 12:40 AM
08ragtop6s's Avatar
08ragtop6s
thanks in advance!
Good day!
I'd love to get the current codes... Do you have a way to pull them for us?! It sounds like the throttle, but yours is acting differently than mine did... It could also be the fuel pump, but the idle at 1200 is curiously not a fuel pump trait...
Let us know please!!
Cheers!!
Old Jun 11, 2019 | 09:48 AM
iceman_jonny
Originally Posted by 08ragtop6s
Good day!
Cheers!!
the only trouble codes are misfires :(
Old Jun 12, 2019 | 04:49 AM
08ragtop6s's Avatar
08ragtop6s
Good day!
Are you able to test the fuel pressure at the rail? You're missing one or both of the things that will give you a misfire... fuel and or spark... timing light or a testing plug could do two things.... could see how hot your spark is and if you pull the plug on the cylinder you test the spark, it should be saturated with fuel since it didn't get burned off... no spark or no fuel should point you in the direction to go....
Good luck!
Cheers!
Old Jun 12, 2019 | 09:57 PM
ItsmeWayne's Avatar
ItsmeWayne
Two things can cause this also: Throttle body failure and accelerator module.
Accelerator Module:
badat
May 7, 2018 11:41 AM
Ixx
Jul 11, 2017 07:09 AM
Gracie22
Oct 7, 2015 09:39 AM
OmToast
May 30, 2004 09:07 AM
chrisneal
Dec 11, 2003 09:15 AM
