JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW New rotors for my MINI GP2 Brakes
Old May 20, 2019 | 12:17 PM
BMC_Kid's Avatar
BMC_Kid
My brother was in town and I finally had time to install my "new" rotors. Made by TCE Performance for me last April. I didn't weigh them but they sure are light! New EBC Red pads installed as well.
Relatively easy install of rotors and pad but glad my brother was there to help as I had to shim the calipers a bit to get some clearance for the pads from touching the hats. Things always go better when your brother can help.
Old May 20, 2019 | 07:15 PM
blue al's Avatar
blue al
Have you any dimensions, both overall, and how much hat to how much rotor ?
visuall looks bigger ?
Old May 20, 2019 | 09:40 PM
BMC_Kid's Avatar
BMC_Kid
Sorry, I didn't accurately measure the rotor. I did place them back to back and they are very close, with the TCE rotor being a hair larger in diameter. I will tell you that the edge of the flange of the hat where it bolts to the rotor is dimensional larger at that point. Enough so, that when we first installed the caliper, there was contact and the assembly could not rotate. To remedy this, the caliper was shimmed about 2mm using stainless steel washers at the two mounting bolts to bring the caliper out away from the center of the rotor. That's about the thickness of a nickel and provided the needed clearance between the edge of the pad and outer edge of the rotor hat.
abner.felix
GP Talk
Jul 17, 2019 03:06 PM
Manny_cooper
Dec 2, 2016 07:02 PM
Carrboroman
Cooper (non S)
Aug 28, 2015 08:13 PM
minsane
Tires, Wheels, & Brakes
Dec 17, 2010 11:26 AM
vodka
Aug 6, 2009 10:07 AM
