fixing a leaking vacuum pump
Old May 20, 2019 | 06:17 AM
genik's Avatar
genik
I had to replace my Vacuum Pump because it had a small leak. It was not from the o-ring but the VP it self. Should i open the VP to try to fix it?
Old May 20, 2019 | 07:33 AM
Scudder44's Avatar
Scudder44
I wouldn't bother, if it was failing then better to dump it. If the VP fails and seizes up it will take out your cam/chain/guide/valves.
Old May 20, 2019 | 08:19 AM
Yupetc's Avatar
Yupetc
VP costs about 100 bucks, safer to get a new one. Those I see in other posts that it can seize and kill your timing assembly.
Old May 20, 2019 | 08:44 AM
genik's Avatar
genik
The bmw vacuum pump or some other after market one?
Old May 20, 2019 | 09:55 AM
Yupetc's Avatar
Yupetc
BMW pump will cost your arm first. Go to ECStuning and look it up, I think Pierburg was the brand I bought. It does come with the gasket. And so far so good, it's been an year.
Old May 20, 2019 | 09:59 AM
Scudder44's Avatar
Scudder44
Yuptec is correct, the original is also Pierburg, note there are two version, the S and the non S so get your part number from Realoem before ordering.
Old May 20, 2019 | 10:41 AM
genik's Avatar
genik
Ok thanks guys
Old May 20, 2019 | 11:34 AM
Its right here for the N14 S/JCW engines.
https://www.northamericanmotoring.co...en-nozzle.html
Tylerlanger1
Jul 5, 2019 04:30 PM
Phasma Felis
Mar 22, 2019 07:46 AM
idickers
Feb 6, 2016 08:54 AM
michmike
Dec 10, 2014 03:00 AM
