Vacuum pump failed?
Old May 6, 2019 | 06:35 AM
genik's Avatar
genik
Vacuum pump failed?
There is oil dripping under the vacuum pump but I can't tell if it's the pumps rubber O ring sealing, or some other issue of the pumps body itself!
Old May 6, 2019 | 06:45 AM
MiniToBe's Avatar
MiniToBe
usually it is the o-ring. also, that corner of the valve cover is known to leak.
Old May 6, 2019 | 06:48 AM
genik's Avatar
genik
Valve cover was just replaced and so was the Vacuum pumps Oring... strange?
Old May 6, 2019 | 06:54 AM
MiniToBe's Avatar
MiniToBe
if they were done already, just clean the area good so you know if there are new leaks....also some times the oil pressure sensor leaks.
Old May 6, 2019 | 06:58 AM
genik's Avatar
genik
Where is the oil pressure sensor located? Is it adjacent to the Vpump?
Old May 6, 2019 | 06:59 AM
MiniToBe's Avatar
MiniToBe
yes. it is to the right of it.
Old May 6, 2019 | 07:06 AM
genik's Avatar
genik
Ok will check, although I must say that oil seems to be dripping from the left side of the VP as the car is seen from front.
Shouldn't be there some code coming up for the oil pressure sensor?
Old May 6, 2019 | 07:13 AM
MiniToBe's Avatar
MiniToBe
a code isnt necessary for small leak, i think. the vacuum pump itself leaking isnt something i've seen on any of my minis. but, to be sure of the source, i suggest just cleaning the area and monitor it.
Old May 6, 2019 | 07:16 AM
genik's Avatar
genik
In the past I did place a clean towel under the vp and after 2-3 days i can see oil on it
Old May 6, 2019 | 07:21 AM
MiniToBe's Avatar
MiniToBe
if that is the case, you may then take out the pump and examine if there is an internal leak. also, was the pump torqued properly when the o ring was done/? aslo, the shop should've been able to let you know if the pump was leaking when they replaced the o ring! no?
Old May 6, 2019 | 07:25 AM
genik's Avatar
genik
Does the vp need to be torqued with specific power like the chain tensioner is needed to?
Old May 6, 2019 | 07:30 AM
MiniToBe's Avatar
MiniToBe
https://www.newtis.info/tisv2/a/en/r...m-pump/Fk0xCj5
10Nm
Tylerlanger1
Jul 5, 2019 04:30 PM
jrw429
Apr 10, 2017 10:21 PM
idickers
Feb 6, 2016 08:54 AM
BBoshart
Jan 21, 2010 11:43 AM
Xymox
12
Jun 7, 2008 09:07 AM
