JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Spark Plugs ...............
Old Apr 14, 2019 | 10:30 PM
dube53's Avatar
dube53
Last week, I received OEM new spark plugs. The part number on the box is 12 12 0 035 933. Curiously, the porcelain is stamped as "champion 12ZR-6SP03. There are different numbers and digits stamped on the metal part with also "Made in France".
Is there anybody who can confirm I have the right parts for the N18 JCW engine before doing the job?
I am asking because the Cooper S plugs look different from pictures and don't need service as early as the JCW 20-30K interval.
Old Apr 15, 2019 | 09:43 AM
With that OEM MINI part number they looks like the Base ( NON S) MINI Cooper plugs for a N12 engine.
https://www.ecstuning.com/Mini-2013-...gine/Ignition/
Your plugs OEM Part 12122293697 or 12ZR6-SPP2 -1 or 12ZR-6SPP2-1
Did you get them from us? Looks like oem used to be beru and they switched to Champion of France.
Old Apr 15, 2019 | 08:10 PM
dube53's Avatar
dube53
No. I will have to call the vendor. I may have the wrong ones.
This is also strange I received 10 instead of 4 and the packing slip was from a large BMW/Mini dealer from NY state.
But...... something tells me they may also be right as a superseded part number being 12ZR-6SP03 that probably identify a different BMW supplier from the last 3 digits.
Old Apr 16, 2019 | 05:20 AM
Ok, let us know what you find.
Old Apr 20, 2019 | 06:12 PM
dube53's Avatar
dube53
I am surprised you don't know since you sell OEM parts.
Anyway, I removed the old ones and they are the same Champion. The new ones are without the 3 blue rings on the porcelain.
Bottom line, for those who own a JCW, changing the spark plugs at 20K instead of 30K as recommended by the manufacturer is not a luxury. They were OK but I understand now why they replaced them twice during the factory maintenance. So it's the 3rd set from new now.
Old Apr 20, 2019 | 08:17 PM
dube53's Avatar
dube53
Also.......
Where can I find replacement for the clip-on covers protecting the ignition coil wires over the valve cover? There is no reference to these parts in Real OEM.
Old Apr 22, 2019 | 12:27 PM
I know, but MINI likes to do supersessions and then they don't update the etk nor anything else and release bulletin internal. Only when there is a massive change over do they update the etk or i just randomly come across it.
I have not found the separate part number for that cover. I know its not part of a new valve cover,. If i did and find it i will post up, I am guessing its part of the wire harness.
Old May 3, 2019 | 07:44 PM
Alpha Motoring's Avatar
Alpha Motoring
They are Champion plugs. I went with NGK on my last N18 car and switched back to Champion OEM plugs
Old Jun 30, 2019 | 04:53 AM
dmath's Avatar
dmath
I'm curious why you switched back to Champion. NGK not worth the extra cost?
Old Jun 30, 2019 | 04:07 PM
Alpha Motoring
It was on my old N18, but IIRC all 3 or 4 plugs failed within 1,000 miles. Luckily no damage was caused, but they were torqued to spec, but the plug itself broke and would spin freely on the base.
Talked to a shop and they said during that time they got a lot of bad NGK plugs as well. Went to OE Champion from the dealer had zero issues.
Old Jul 1, 2019 | 07:12 PM
dmath's Avatar
dmath
Thanks for the information.
Shen456
Jun 15, 2021 03:51 PM
2004JBMINI
Jul 2, 2012 12:02 PM
Archanum
Jun 17, 2008 01:40 PM
