winter tires on lowered MCS
Old Nov 28, 2004 | 12:44 PM
texascrude's Avatar
texascrude
Can anyone recomend a performance winter tire in 16" (I'm planning to get the R83 Mini wheel 6.5" wide,don't know the offset).My JCW has Eibach springs. I did try a 15/205/60 and they rubbed when I had weight in the back or did spirited driving.Would 16/195/55 rub?
Thanks in advance for any info.
Old Nov 28, 2004 | 01:54 PM
tontobird's Avatar
tontobird
I like the R-84s, they are lighter by 2.5 lbs each. But they are both very attractive. The stock tire size for those wheels is 195/55/16, so you should have no problems.
You're in Texas? Or is that just your name? What do you mean by winter performance tires? Are you expecting to drive in snow?
Old Nov 28, 2004 | 04:08 PM
texascrude's Avatar
texascrude
No, Canada,West Coast, but might do some driving up to Whistler (mountains)...When the forum asked for a username,I looked around the house and saw that name on one of my guitar amps,hence "Texascrude".
Yes, style 84 is cool, so is 87...haven't decided yet...I'll have to do some searching for 195/16/55, not sure if there is a big selection,not like 205's anyway.
Old Nov 28, 2004 | 06:39 PM
lotsie's Avatar
lotsie
Get some 15 inch winters and be done with it,Lighter,cut through the snow better,and the 1/2 inch of lift means nothing.And your speedo will not be out by much
Old Nov 28, 2004 | 09:32 PM
tontobird's Avatar
tontobird
Are you strictly using these for winter tires? If so, the R-87 would be a good choice, having a more narrow footprint. Not sure what tire size would be appropriate for it. You could contact the Tire Rack to get some ideas. If you're going to use the same wheels for summer, and just change tires, I'd stick with the R-83s or R-84s.
lot15 mentioned in another thread that he was pleased with the Pirelli 190 Snowcontrol Winter tires. At this time, through the Tire Rack, you can only get them for 15" wheels.
https://www.northamericanmotoring.co...ad.php?t=33538
Blizzaks are always popular for snow.
I bought take-offs from my dealer, the 15" holies with all season Continental Touring Tires. They worked well for me last winter, and we had quite a bit of snow.
Old Dec 3, 2004 | 12:52 PM
texascrude's Avatar
texascrude
No... I'm running 215/40/17 Yokos' as my normal tire,so I would be getting an extra set of wheels (16") for the winter ones,but I still want them to look good. Do you think there would be any rubbing issues on 195/50/16's?
Old Dec 3, 2004 | 05:30 PM
tontobird's Avatar
tontobird
If you get the R-83, R-84, or R-87 that size tire will be fine. If you get different wheels, you will then need to consider the offset and speak with somebody like Alex at the Tire Rack.
Good luck!
Old Dec 4, 2004 | 09:29 AM
90STX's Avatar
90STX
I've used the same set of 205/50-16 Artic Alpins on my stock X-lites for the past two winters and they are back on car again for winter #3.
First winter, stock suspension.
Second winter, SPAX coilovers and autocross alignment (never bother to change as it was still working fine).
Now, PSS9s and autocross alignment (-2.2deg camber front, -1.8deg rear) The car is set at the middle of Bilsteins recommended range, which gives me 2.5" of ground clearance measured at the middle of the front air dam (the lower one directly under the radiator, which is the lowest spot on the car). IIRC, that is about 1 3/4" lower than stock.
I have never experienced rubbing with any of the above setups. I have driven hard enough to get all four tires to break away, but generally I'm much nicer to these tires as they aren't intended to deal with that level of abuse.
If you are rubbing, the camber settings may be the difference.
Scott
90STX/SM
Kimolaoha
Dec 5, 2020 09:32 PM
FLYM1N1
Oct 13, 2015 04:33 PM
col127
Aug 21, 2015 02:11 PM
minipopkart
Aug 13, 2015 05:22 AM
Dashdog
Aug 10, 2015 06:17 AM
