R50/53 Rear hatch replacement
Old Mar 16, 2019 | 11:17 AM
smurfskier's Avatar
smurfskier
So my hatch is rusted and I am going to by a used one. Has anyone done this replacement already? My big question is do I have to splice the wiring harness or is there a connector to unhook the wiring from the hatch to the rest of the car?
Old Mar 17, 2019 | 09:49 PM
JoeyF's Avatar
JoeyF
Im doing the same. Short answer, no plug and kinda a pain in the ***.
remove the plastic panels. Remove the brake light. Then go in and unplug all the wires. Pop off the clips that hold the wiring to the sheetmetal. Then gently pull the wiring up and out through the top.
im at this point now. Feeding the wiring back into the new hatch looks like a nightmare...
Old Mar 18, 2019 | 04:50 AM
smurfskier's Avatar
smurfskier
Thats what is what i was figuring had to happen. Trying to decide if it will be easier to cut and splice the harness under the headliner. Thanks for the response..
Old Mar 18, 2019 | 07:04 AM
JoeyF's Avatar
JoeyF
I've thought about splicing as well. When I pulled my new hatch out of the junkyard I just said F'it and cut the wires. There is a funky cable going down the driver side, almost looks like old school antenna wire. I doubt that would splice. No clue what it does, it goes to a box of some sort midway down the driverside of the hatch.
I suppose if you were to splice it you could hide everything in the rubber accordion boot between the body and the door.? Should be plenty of room in there for the splices.
On mine I and just routing the wires. The car sits inside all winter, I can walk away from it if I get pissy. If your car is a daily I totally understand saving a few hours by splicing...
Old Mar 19, 2019 | 05:14 AM
JABowders's Avatar
JABowders
Veteran: Army
... the process you will end up doing will greatly depend on the condition of the hatch you get as a replacement... if the wiring harness is cut at your new hatch ... well that would be a cause to do off set splices. if it is the complete harness to the connector, then you will be dropping the headliner to run the harness.
Best of luck.
Motor On1
Old Mar 19, 2019 | 08:26 AM
lotter1's Avatar
lotter1
I replaced my hatch. It really was not that big of deal. Removed all the wires from the hatch, with the hatch was still connected to the car. Reinstalled the new hatch and then ran the wires back in to the hatch. Took maybe an hour to do the wiring in and out.
frappucino
Apr 6, 2018 04:08 PM
fridayxiii
Feb 5, 2018 08:57 AM
JeffHarper
Oct 10, 2017 04:39 AM
dstehle
Sep 17, 2017 08:53 AM
Drumsound
Aug 29, 2017 05:25 PM
