Off Road Tires for Countryman all4
Old Feb 4, 2019 | 06:27 AM
spearmin's Avatar
spearmin
Can anyone recommend an off road or simi-offroad tire that will fit a stock countryman All4. I'm looking for something like the BFG TAs or MTAs. Really just want them for the snow amd the looks for the winter. There has to be something out there....
Old Feb 22, 2019 | 12:49 PM
Saltysalt's Avatar
Saltysalt
there is, but it will be oversized for the tires that typically come with the car. youll also have to look at 16's since most off roading tires have larger sidewalls. but you should be looking for 235 or larger 60-70 series
Old Feb 22, 2019 | 01:37 PM
iwashmycar's Avatar
iwashmycar
205/70r16 is about as big as you can go without lifting it.
example: https://www.northamericanmotoring.co...ml#post4173974
Should probably consider lifting it so it actually "completes the package". If it is in fact just for winter, get snow tires like the guy in the thread above. Offroad tires actually typically suck in snow. I'd take a highway tire anyday over an all-terrain, and especially a mud-terrain. Those are death in slush and ice.
Old Apr 8, 2019 | 02:41 PM
bmwr606's Avatar
bmwr606
i test fit 215/70R16 on mini oem 16x6.5 et 46 wheels. they fit no problem, no rubbing and i have the factory sport suspension.
loaded the car up with 6 people until suspension was bottomed out, no rubbing.
you can go up to 28 inch OD without a lift.
i am running 205/70R16 winter tires since 2012 (27.3 inch OD)
Old Apr 15, 2019 | 08:31 AM
BDI's Avatar
BDI
225/65r17 BFGoodrich All-Terrain T/A K02
These are great in all conditions including snow. Had to slightly mod the fender lining because it would rub on full lock. Other than that, it fits and looks great without a lift.
Old Apr 20, 2019 | 06:40 AM
BRG04's Avatar
BRG04
BDI, what are the specs on your wheels?
Old Jul 12, 2019 | 07:55 PM
ChrisALL4's Avatar
ChrisALL4
What is your wheel size/width and offset? Thanks.
Old May 27, 2020 | 11:50 AM
PDXLAPIS's Avatar
PDXLAPIS
BDI,
What's the offset on your rims? Thanks!
Old Jul 27, 2020 | 06:14 PM
BDI's Avatar
BDI
Originally Posted by PDXLAPIS
BDI,
17x7.5 et35
Old Aug 28, 2020 | 06:19 PM
veritas137's Avatar
veritas137
Installed my 17” LP Aventure wheels today, M7 lift kit goes on Sunday.
Old Oct 19, 2020 | 01:16 PM
J.Hec's Avatar
J.Hec
Sizing
This looks great, any idea if the 225/65/17 would work for the R60 countryman? So far I’m only seeing 215/65/17 but I feel like the 225 might work?
Old Aug 2, 2021 | 02:13 PM
Rebel-Breath's Avatar
Rebel-Breath
Fender mod
what were the mods to the fender lining? Did you do it yourself or was it done for you? Before or after installation of tires?
Old Jan 2, 2022 | 05:05 PM
OverRev's Avatar
OverRev
[QUOTE=veritas137;4551644]Installed my 17” LP Aventure wheels today, M7 lift kit goes on Sunday.
Any update on the M7 lift kit install? I am tempted to get it for a little more ground clearance.
Old Jan 3, 2022 | 10:44 AM
veritas137's Avatar
veritas137
Love the M7 kit but then I bough it for half price. If buying new I would probably stick with the Journeys kit. I saw your post in another thread and I think the rear does come with spring blocks also they just aren't shown in the picture.
What size tires are you running? Your Mini looks awesome!
Old Jan 9, 2022 | 08:57 PM
OverRev's Avatar
OverRev
Ya, many I will got for the Journey’s kit. Tire are same at the Red one above, 225/65R17 KO2, I would prefer Toyo OpenCountry AT3 but no stock.
Old Jan 27, 2022 | 01:54 PM
crazycuz2k's Avatar
crazycuz2k
Toyo AT3’s we’re in stock at discounttire. Just purchased a set 215/65R17, will put them on new rims and 2 inch M7 lift
Old Nov 29, 2024 | 05:40 PM
Bruno69's Avatar
Bruno69
Tire size
will 225/60R17 fit on my 2016 mini cooper countryman all 4
Old Dec 9, 2024 | 06:10 AM
Bruno69's Avatar
Bruno69
oversized tires
How did you modify the wheel walls.. i have a set of 225/60 R17 and I have a 2016 Countryman All4 will i have to modify my wheel walls for these?
Old Dec 9, 2024 | 06:11 AM
Bruno69's Avatar
Bruno69
How did you modify the wheel walls I have a set of 225/60 R17 and I have a 2016 Countryman All4 …
spearmin
Tires, Wheels, & Brakes
Dec 27, 2019 01:46 PM
