Navigation & Audio Are BMW headunits convertible to Mini by coding
Old Jan 23, 2019 | 01:02 AM
ensaimadeta's Avatar
ensaimadeta
Hi Miniacs,
I am going through the upgrade of my simple boring Visual Boost (thanks god it is boosted) to a NBT EVO High with Carplay support. I have seen in an eBay listing that the seller claims that a HU is for both Minis and BMWs. I asked the question and he said that they are compatible, you just need to code for one or other brand.
Does anyone here know if this is true? Can I just pick the latest BMW ID5 or ID6 HU and just code to Mini? That would be awesome, as there is plenty of options of BMW and less for Mini.
I will dig on my own as well, but should any of you guys have experience or knowledge on this I will appreciate.
Regards from Catalonia!
Joan.
Old Feb 6, 2019 | 09:23 AM
markbam's Avatar
markbam
Yes, I had a BMW ID5/6 headunit coded to work with my F56. It fits and works flawlessly. Be careful about the GPS port though. Most newer BWM units don't have the blue GPS port and you'd need an ATM emulator.
Old Feb 6, 2019 | 09:26 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
How about a picture of it installed and any other info?
Old Feb 6, 2019 | 09:31 AM
markbam's Avatar
markbam
Some hardware pictures.
Old Feb 6, 2019 | 10:33 AM
Minnie.the.Moocher
That is awesome. Probably a budget buster for my needs, but I still want it!
Old Feb 6, 2019 | 10:42 AM
markbam's Avatar
markbam
https://www.northamericanmotoring.co...y-project.html
There's a very good breakdown in this thread.
It wasn't cheap by any means but I feel like it completes my Mini. The Carplay integration with iDrive is just really nicely done.
Old Feb 7, 2019 | 06:27 PM
6FT6's Avatar
6FT6
Hi, where did you send the unit to get the coding done? Or was it done remotely?
Looks like you used an ATM emulator, which did you get?
I have an id6 BMW nbt2 evo that I would like mini firmware installed, so just getting as much info necessary if I’m gonna do it myself or not.
Old Feb 7, 2019 | 06:34 PM
markbam's Avatar
markbam
I have an id6 BMW nbt2 evo that I would like mini firmware installed.
I bought it from an ebay seller in Bulgaria who was able to flash and code it before shipping. It was plug and play.
Old Feb 7, 2019 | 06:36 PM
6FT6's Avatar
6FT6
Ah ok, guess I’m gonna have to do it myself.
Old Feb 10, 2019 | 05:22 AM
BazV's Avatar
BazV
nice work. Any details of the ebay seller please?
Old Feb 26, 2019 | 04:44 PM
pillpusher84's Avatar
pillpusher84
You need to change simply a few parameters under NBT2 for the MINI “theme” ... it isn’t separate software ... i’ll have to pull a few parameters to tell you wha needs to be changed.
Be be aware that you will also need to change the amplifier settings, vehicle style and model, telematics ECU type, as well as screen size and type
you can use the evo headhunt with or without a new touchscreen .... simply code the system for the right size, supply 12v screen power from another source. As apix2 screen is 9v, while a apix1 screen is 12v and only 16bit color vs 24 bit color.
simply changing the build date on the vehicle order and then VO_coding the nbt2 evo will be the easiest to make all OEM changes to the unit
Old Sep 9, 2019 | 08:59 PM
6FT6's Avatar
6FT6
Ive got my nbt Evo coded, fsc added for Nav, wireless CarPlay etc and it all works. The final thing to resolve is the 3D graphics, animations and manual; they are for an f60 and not my f56 and the online manuals are inaccessible. How do I get the unit to display the f56?
Old Jan 14, 2020 | 02:49 AM
William Choi's Avatar
William Choi
To answer the OP's question. Yes you can flash any BMW Evo to run Mini HMI. I only look for evos to buy not Mini Evos.
Just got mine updated today with F55. And the manuals. It was a pleasant surprise. I was using tool32 for something else. Re injected cafd it just magically appeared.
I had countryman graphics on my retrofitted id4 to id5 also (another unit). I'm gonna try the same tool32 job on this unit shortly. Will let you know.
Last edited by William Choi; Jan 14, 2020 at 02:51 AM. Reason: Add answer to OP question
Old Jan 14, 2020 | 08:45 AM
Mattia M.'s Avatar
Mattia M.
Hello William, thanks for your feedback.
May I ask you what's the correct procedure to flash a BMW's evo headunit to have Mini HMI?
Thanks in advance
Cheers
Old Jan 16, 2020 | 01:47 PM
Mattia M.'s Avatar
Mattia M.
Hi all,
I'd like to give to the community another feedback about this topic: yesterday my coder was able to successfully flash my BMW's Nbt Evo (coming from a G01 vehicle) and convert it to Mini F54 GUI.
He told me he flashed the headunit with my VIN using latest F56 Psdzdata, and then he loaded FSC files without problems at all.
Matt
Old Jan 18, 2020 | 09:05 AM
William Choi
What software version did he flash to? No need to know the istep.
Old Jan 18, 2020 | 03:23 PM
Mattia M.'s Avatar
Mattia M.
Cool
Hi William,
which software version are you asking for?
Below some pics of the installation performed today:
Old Jan 19, 2020 | 01:13 AM
William Choi
Nevermind! Answered my own question while on the bench!
F57
F56
F60
F54
F55
Old Jan 19, 2020 | 03:01 AM
Mattia M.'s Avatar
Mattia M.
Old Jan 22, 2020 | 12:32 AM
Marcio da Mata's Avatar
Marcio da Mata
How are you. All right ? can you let me know the e.bay seller in Bulgaria? Thanks.
Marcio.mata@me.com
Old May 14, 2020 | 07:57 PM
Liveinlow's Avatar
Liveinlow
F57
F56
F60
F54
F55
Hi William, meet some problem here, would you like to explain more about how to specify the model? BTW, if vehicle doesn’t match EVO’s one, Manual function will be disabled?
thanks a lot
Old May 14, 2020 | 08:01 PM
Liveinlow's Avatar
Liveinlow
F57
F56
F60
F54
F55
hi William, just meet the same problem here, would you like to explain more to help me to solve it? BTW, if the model specified in EVO doesn’t match my vehicle, the function “Manuals" would be disabled? Mine is disabled...
many thanks!
Old Jun 5, 2020 | 09:50 AM
Smittysweets's Avatar
Smittysweets
Question Coder in USA
Can someone assist me finding someone who can flash/program/code a head unit for me? (Im willing to pay) I want to retrofit 8.8 touchscreen to a 2017 F57 convertible S, my car is 6.5 visual boost I know is doable... The more I read about how to do this I just realize Im not capable to do it by myself and I don't want to brick this expensive unit... or use a ATM emulator either.
I was able to find a seller on eBay who has the parts including a headunit i need, is HW4.1 not sure if it has GPS but i needs to be configured to my VIN number, activated the CarPlay, put the right graphics for my car... and I don't know what else is need to be done to get the navigation working...
Im located in USA.
I will appreciate the help.. thanks all
F57
F56
F60
F54
F55
R53hyperblue
Mar 17, 2019 09:52 AM
R53hyperblue
Sep 12, 2018 04:50 PM
corral6200
Dec 15, 2017 11:59 PM
wikedgolf
Off-Topic :: Autos
12
Jan 31, 2007 09:01 PM
