R50/53 Rear Brakes Locking up
Old Jan 20, 2019 | 07:02 PM
wildwilly2004's Avatar
wildwilly2004
Tap the brake on the R50 and the RR brake will lock up, especially in the snow. Very dangerous car at this point. LR also dragging a bit as well. Ordered 2 new Calipers, Rotors and brakes. I guess this is a pretty common issue with these cars?
Old Jan 20, 2019 | 07:22 PM
Minidogger's Avatar
Minidogger
Not sure how a bad caliper can make it lock up early. Seems like a bad proportioning valve? Or possibly poor tires.
Old Jan 21, 2019 | 04:36 AM
Tgriffithjr's Avatar
Tgriffithjr
Could be pistons seizing.
Old Jan 21, 2019 | 05:27 AM
wildwilly2004
I am pretty sure it is the piston. It will release after 15-30 Seconds most times.
Minidogger- What do you mean by "locking up early" ?? You tap the brake and it locks.....I went last night and swapped cars with my son at work so he could safely get home. I drove all the way home never touching the brake. When I got to my drive, I hit the brake....And it stuck.....
Old Jan 21, 2019 | 05:44 AM
Tgriffithjr
It’s most likely the piston. Proportioning valves rarely have issues. I would pull the caliper and see if you can manually turn the piston. You will need a brake piston tool. Can rent at auto parts store. You might be able to free it up or it might be cocked. Look for leaking brake fluid around the piston seal. You can also try pulling the boot away and spraying some rust buster of your favorite flavor around the piston. Just don’t tear the boot.
Old Jan 21, 2019 | 05:51 AM
wildwilly2004
Thank you. I have one of the tools, I think...My MR2 rear pistons need screwed in as well..Should be the same?? Probably not with BMW..lol. I am not even going to mess with it...The car spent the majority of it's 80K plus miles in Canada.....So....they are going to need replaced and that may free up for a little while...., but go right back to sticking. It is my son's car.....So I really need him to be safe out there....and the car is dangerous in the snow...even with 4 snow tires.....if there are dry conditions....the wheel will turn......but, hangs up every x brake it tapped.
Old Jan 21, 2019 | 05:56 AM
Tgriffithjr
Sounds like it needs some serious front end work especially if it’s been in the far north for a while.
Old Jan 21, 2019 | 06:06 AM
wildwilly2004
All is good up there.....so far.....Piece by piece...lol Runs great, looks fantastic..was garage kept in Canada. Just want to get a couple years out of it...Needs a muffler.....
Old Jan 24, 2019 | 03:27 PM
wildwilly2004
All replaced today....Brakes, Rotors and Calipers. Rt rear was seized with boot missing.
Old Jan 24, 2019 | 05:51 PM
Tgriffithjr
Good deal!
Old Jan 25, 2019 | 01:29 AM
RudeJoe's Avatar
RudeJoe
We had to replace both rear calipers on my son 2002 R50 last year because the parking brake components siezed up. Salty western New York...
Old Jan 25, 2019 | 03:43 AM
wildwilly2004
I hear ya,,NW PA here...and my sons car came from Canada
Old Jan 25, 2019 | 04:19 PM
wildwilly2004
Well, MPG is going to go way up.....the thing rolls so freely now it is amazing how badly the brake were hanging up.
Old Jan 25, 2019 | 04:21 PM
Tgriffithjr
I’m surprised you didn’t smell the hot brake.
Old Jan 25, 2019 | 04:47 PM
wildwilly2004
Never.....very weird. Of course.....it has been very very cold too.
Old Feb 1, 2019 | 11:55 AM
wildwilly2004
Replaced brake wear sensor w/ one from Rock. Worked like a charm....both lights went out!!
minsane
Tires, Wheels, & Brakes
Dec 17, 2010 11:26 AM
AFireInMINI
Classic Mini Talk
Jul 4, 2009 03:37 PM
bergie07
Apr 1, 2008 03:15 AM
Rennie
Apr 7, 2007 09:12 AM
