2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Phone Mounting Solutions
Old Jan 17, 2019 | 10:52 AM
MNCNTRYMN's Avatar
MNCNTRYMN
Curious to know what you have done for your phone. Vent mounts? Windshield mounts? Something custom? Integrated charger?
I need something but would like to know what you've done.
Thanks!
Old Jan 17, 2019 | 11:12 AM
Vernonite's Avatar
Vernonite
This is mine
Old Jan 17, 2019 | 11:41 AM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
I have something similar to the above posted photo in both our F series cars. Of all the phone mounts I've used the placement and ease of use is the best so far. It is an imitation of the MINI click and drive set up. Also Cravenspeed makes some nice similar style units in metal.
Old Jan 17, 2019 | 04:00 PM
Evlkarl's Avatar
Evlkarl
My last F 56 had the click and drive already installed loved it my current F54 does not and I do not want to spend the $$$ on it because I feel like it is totally overprized so I was looking at the same mount as one of our members bought I just can not figure out how to install it since they always show them long screws in the picture.
Old Jan 17, 2019 | 04:24 PM
Vernonite's Avatar
Vernonite
It is actually easy to install. Under the speedometer there are two rubber round covers with a hole in the middle. Take a small screw and insert it in the hole. Turn to make it tight then pull out the plug. Repeat on the other side. Then remove the two screws they covered. At this point the speedo will be loose. Pull it forward. Remove the two screws in the back. Then use the two longer screws they supply to replace them holding the new phone holder in place.
I hope this helps.
Old Jan 18, 2019 | 06:45 AM
Blu_lite's Avatar
Blu_lite
Here is a link for instructions.
https://www.newtis.info/tisv2/a/en/f...ter/1VnXqusF6v
On a side note, does anyone know how to change the wireless phone charger in the arm rest?
Thanks,
Old Jan 18, 2019 | 08:05 AM
MNCNTRYMN's Avatar
MNCNTRYMN
Ooh I like this. Got a link? Thx!
UPDATE!
Saw a video on the CRAVENSPEED Gemini mount. Love it. Bought it.
https://www.cravenspeed.com/gemini-p...ount-for-mini/
Thanks for leading me to my new mount.
Old Jan 18, 2019 | 09:35 AM
Minnie.the.Moocher
Cravenspeed makes some really nice stuff. Good luck with it. Kind of sorry I cheaped out on mine, but it was free.
Old Jan 20, 2019 | 08:56 AM
OVREZY's Avatar
OVREZY
This works great
SCOSCHE MAGDM MagicMount Universal Magnetic Phone -- note: since you put a slim magnet on the back of your phone, it will not work with wireless charger
Old Jan 23, 2019 | 09:42 AM
MNCNTRYMN's Avatar
MNCNTRYMN
Update on the CRAVENSPEED Gemini Mount...
It's fantastic! Only "complaint" would be sometimes the phone would shift on the magnetic mount. Needed to find the sweet spot between the case back and phone (mounted portrait and landscape) to minimize the movement over bumps (alway in SPORT mode).
It's pricey, but solid! Installation took 10-15 minutes and it pretty easy as long as you're careful removing the 3 electrical plugs when pressing the tabs and you don't over-tighten the new screws that come with the mount. Apparently the threads behind the tachometer are plastic.
Hope this helps anyone considering this mount.
Cheers!
Old Jan 23, 2019 | 06:56 PM
Evlkarl's Avatar
Evlkarl
Vernonite, Thank you it will help me a lot.
Old Jan 26, 2019 | 07:43 AM
MNCNTRYMN's Avatar
MNCNTRYMN
Contacted CRAVENSPEED... They're sending me a new magnetic mount that's apparently stronger than the one originally sent. The one one has a white "CS" on it. Good on them!
May 9, 2017 03:29 PM
GoBadges
Oct 1, 2015 11:10 AM
jondell
Mar 22, 2010 04:32 PM
RandomGemini
May 25, 2008 08:58 PM
MaxMini81
11
Sep 7, 2007 07:51 AM
