Looking for a thread on a sticky wicket -- no, a sticky throttle on R56 with the N14
Old Dec 21, 2018 | 05:26 PM
PSUFencer's Avatar
PSUFencer
I've searched the threads but I must be missing it. Can someone point me at a "common problems" thread regarding a sticky throttle. The car throttle is stuck way high on a 2009 Mini Cooper S R56 with the N14 engine. I just changed out the PCV breather hose, that is all that I did -- promise. HELP!
Old Dec 22, 2018 | 07:24 AM
Oldboy Speedwell's Avatar
Oldboy Speedwell
I liked that you used the sticky wicket Britslang bit,
so I'll respond.
I'm an R53 guy and don't know nuthin' regards to R56, but I did find a thread with a couple of ECU reset techniques that may possibly help?
https://www.northamericanmotoring.co...ttle-body.html
Is your problem a sustained high idle?
Could possibly be a vacuum leak.
Surging idle?
Some R56 owners have reported cracked valve covers which cause that symptom.
I'm just throwing darts though --- hopefully someone more knowledgeable than myself will chime in.
Old Dec 23, 2018 | 08:29 AM
PSUFencer's Avatar
PSUFencer
Well thanks -- those are all possibly great darts! She was getting periods of a sustained high idle. Told me that she had this happen once before when she used bad gas. I got in her car to look at it and I noticed that her carpet was pushed up against the base of the accelerator. So, I think this was actually a case of the carpet keeping the accelerator pressed.
Old Dec 23, 2018 | 09:38 AM
Oldboy Speedwell
Glad to hear it was a simple fix!
And,
you get bonus points for good sleuthing.
If it was a case where she had taken it in to a mechanic to look at they would've at least charged a slight diagnosis charge, or worst case scenario a shady mechanic would've told her that the johnson rod needed adjustment and slapped up some crazy fee LOL
Good on you for solving the problem!
t0ad
Jan 30, 2015 02:12 PM
Carmichael
Aug 20, 2013 12:33 PM
rustyeuro
Cooper (non S)
Jul 14, 2011 08:42 AM
jc8899311
Cooper (non S)
16
Mar 11, 2010 11:56 AM
paulmon
Mar 19, 2003 03:12 PM
