R56 non S , cold start problem
Old Dec 21, 2018 | 07:58 AM
Cristian Dobre's Avatar
Cristian Dobre
hello ,
Only happens if the car was sitting overnight and the temp is below freezing.
For 10 seconds , after i press start button work/sound just fine , after that rough idle for 20-30 sec.
After that works fine for the rest of the day .
It has over 260k km (~160 k miles )
I have changed : oil , spark plugs, filters (oil, air) , catalyst, upside part of the engine ( the one with the logo) ,distribution,
And i get the "check engine" sometimes and P111B error.
https://www.youtube.com/watch?v=VoZR...ature=youtu.be
Old Dec 21, 2018 | 08:13 AM
MiniToBe's Avatar
MiniToBe
The vid shows a car with 151km?
Is the car convertible? if not, your cluster needs to be coded properly.
It sounds like a vacuum leak. did you check all connections to the intake manifold and PCV?
Old Dec 21, 2018 | 08:22 AM
Cristian Dobre
It show's 151 but i has 260+. When i bought the car I changed , to avoid discussion with my parents.
Is not convertible.
I possible to be a vacuum leak, thank's for suggestion
Old Dec 21, 2018 | 08:40 AM
MiniToBe's Avatar
MiniToBe
lol...i got you...
but in general, you need to fix the cluster too...it has the wrong coding. i made that mistake few years ago and one of the subsequent issues was draining the battery. That code kept coming even when the car was turned off.
to do the coding you'd need NCS expert along with K+Dcan cable.
Old Dec 21, 2018 | 08:54 AM
Cristian Dobre
Why do you say it has wrong coding ?
My car was produced for European Union , maybe is different from US
I got the cable and soft but i'm a noob , i will pay somebody to do it.
Old Dec 21, 2018 | 09:04 AM
MiniToBe's Avatar
MiniToBe
when you started the car, it showed the two seaters as a convertible or roadster...the coding actually takes less than five minutes.
The car is ON (not running)
fire up NCS
go to file ---> load profile ---> Expertmdoe ---> (F1) ---> (F3) ---> R56 ---> CAS ---> (F6) ----> choose ECU ----> KOMBI ----> process ECU.
Old Dec 21, 2018 | 12:15 PM
Cristian Dobre
That PCV piece is part of cylinder head cover ? (http://www.realoem.com/bmw/enUS/show...diagId=11_3953 )
I have changed that whole piece in April.It must be a hose problem .
Old Dec 21, 2018 | 12:26 PM
MiniToBe's Avatar
MiniToBe
most likely...check the hoses on the left side specially the one under the throttle body.
Old Jan 28, 2019 | 01:33 AM
Cristian Dobre
Resolved :
Software update and cleanning one of the VANOS
EML code was a separate issue , one senzor (near the dip stick ) was clogged with oil.
GoKickyFastOk
Dec 13, 2022 06:23 PM
Spank
Jun 3, 2021 08:31 PM
Theodor
Oct 11, 2020 07:07 AM
johntotah94
Dec 27, 2018 11:35 AM
Bryan.vfr
Aug 17, 2015 05:33 PM
