Drivetrain Revolution Motor Works Standalone ECU
Old Dec 9, 2018 | 10:37 AM
knt's Avatar
knt
Hi,
Is there any update for this ECU
https://www.northamericanmotoring.co...is-coming.html
maybe a release date.
Old Dec 9, 2018 | 02:37 PM
BigBoost's Avatar
BigBoost
Those guys come and go
If your looking for a stand alone
check out scs delta
but not really worth it
To be honest
with ya
some of the fastest mini’s
in north American / Canada
are runing stock ecu
with a good remap
Old Dec 9, 2018 | 04:27 PM
knt's Avatar
knt
Thanks for the reply.
Are you using SCS Delta ECU?
Currently the engine is getting a rebuild.
Previously the tuner couldn't access the ECU to tune the car which already has a Manic Motorsport Stage 2 tune.
With another and future Manic Motorsport tunes the cost will be too much.
So now I'm looking for a standalone/piggyback ECU to enable full access tuning of the new build without disabling other car functions.
I have emailed SCS Delta for more info.
Old Dec 9, 2018 | 05:12 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
rmw does not come and go, he's been around many years
Old Dec 10, 2018 | 03:12 AM
knt's Avatar
knt
check out scs delta
To be honest
with ya
with a good remap
Are you running SCS Delta on one of your minis?
What standard functions are missing from the car with the SCS Delta?
I've contacted SCS directly
"Thanks for the email and interest in our management systems.
Yes our management system will work with the JCW - we have the correct
scaling for the MAP sensor (3.0bar vs 2.5bar) and a base calibration for
an engine.
The ECU is fully unlocked and every aspect of the tuning can be modified."
Old Dec 10, 2018 | 04:54 AM
BigBoost's Avatar
BigBoost
Definitely not wrong
they have been around for many years
But like I said they come and go
especially n14 / n18 stuff
There was a post on one of the Facebook pages a few years back
Entitled where is Janne
and if I remember correctly
They just called it a loss on there standalone anyways
They were trying to use links
& the
Fuel pumps pretty much was non-compatible
Check out RMW forums
if they are still up
But before warned
it was pretty much all just trolls anyways and if you don’t have a 53 they don’t want you on their
Old Dec 10, 2018 | 05:21 AM
knt's Avatar
knt
Old Dec 10, 2018 | 07:19 AM
thebombardier's Avatar
thebombardier
Making a single standalone for the second gen Minis would be very difficult just knowing that there are 3 different engine revisions across 6 years that require 3 different ECUs. There's the N14 and the two versions of the N18. I don't know how different the N14 and first version of the N18 are but I know it's enough they they did have different ECUs. And the drivers in the ECU for the HPFP are different between the first and second version of the N18, meaning the actual components on the boards are different. Haltech was working on it but they basically said they couldn't do it, as I imagine the development costs were way too high for a niche market car.
Plus, as BigBoost said, RMW seems to only want to put big time and effort into the R53 platform. Last I knew he still doesn't tune N18s at all because the encryption is tough to crack, and the N14 tuning is few and far between because he only dyno tunes them. He put out a tune for the F series Minis but that's because they're easy to get into the coding.
Old Dec 11, 2018 | 06:11 AM
BigBoost's Avatar
BigBoost
super confused?
got an email saying
knt posted
but i cant see the post that was in the email
try to re-post
Old Dec 11, 2018 | 12:44 PM
knt's Avatar
knt
I think when I posted the post had to be checked over or something and now it's posted above.
Old Dec 11, 2018 | 09:04 PM
BigBoost's Avatar
BigBoost
Ahh..i got ya'
Not sure what you are trying to get at
but a flash tune will be a lot cheaper then a standalone
not sure if you are new to the mini word
but the mini word really does have
a lack of quality
parts/company's out there
as of right now i believe theirs only one company out there
that is making / selling a standalone
"SCS-delta"
witch those guys are supplying the ECM
for the mini challenge car's
The only functions i lost with the SCS was
cruise control do to lunch control / 2 step
it's a solid product
little over kill but solid
Old Dec 12, 2018 | 03:14 AM
knt's Avatar
knt
Thanks BigBoost.
So other standard car functions will still all work i.e. alarm, climate control, central locking etc... apart from cruise control?
I think I might have to go with SCS Delta as the original ECU with Manic Motorsport stage 2 map is no good with a hybrid turbo and forged engine rebuild, as the rebuilder and tuner can't access the ECU for the remap.
I've heard with a standalone ECU the tuner has full control and is not limited to working within the parameters of the original ECU.
Thank you again.
Old Dec 12, 2018 | 11:41 AM
oldbrokenwind's Avatar
oldbrokenwind
Hi,
I've been waiting for this ECU since 2011. Gave up a couple years ago and went with Manic's stage 4. Love it!
check out scs delta
To be honest
with ya
with a good remap
I can't speak about being one of the "fastest", but definitely one of the most powerful --- last dyno was 368WHP & 353 ft-lbs torque. I should note that the dyno charts show the turbo to be the limiting factor --- boost is dropping off at high RPM's. This on OEM fuel and ignition systems with Manic's stage 4 and heat range 9 plugs. And even with all my mods and power, I still get about 39MPG, when I keep my foot out of it. It was built as a "sleeper" and that's how it's used --- mostly.
My Manic tuner assures me that Manic is back in business doing custom tunes. If you're concerned about "disabled car functions", ask your Manic tuner which function, and to what extent they have been "disabled", and why. Considering the cost of a stand-alone, plus the unknown reliability and cost of a new tune, I'd think long and hard about staying with Manic.
I gotta admit that my mini is broken again, but I can assure you that the problems have all been of my doing, not the tune. I'd be very suspicious of claims that Manic's tune caused an engine to blow up --- there are just as many, if not more, claims of un-tuned engines with the same failures. No tune will compensate for shoddy workmanship or bad parts.
All this being said, I'm still gonna follow SCS Delta's progress. Combined with an upgraded HPFP and injectors (when available), it might be a great add-on.
Old Dec 12, 2018 | 01:37 PM
knt's Avatar
knt
Thanks oldbrokenwind.
It's not the Manic Motorsport tune itself, it's the costs of the remaps with changing mods e.g. £720 stage 3 and stage 4 not even listed.
So hope to go with standalone ECU and not only be tied up with Manic tunes.
Hope you get your mini all sorted soon.
Old Dec 12, 2018 | 02:32 PM
BigBoost's Avatar
BigBoost
oh snap your over sea'
get a hold of the Mandingo's over at lohen
the scs delta starts about £1,650.00
£1,650.00
£720
am i missing something
if your trying to get away from manic i
really cant blame you
not a big fan of them
but there are other company's out there
Manic is back selling stage 3 ??
for a while they where no longer offering it
to the us market
just
double check there webpage
it says they are offering 3 map's
so they must be back
Old Dec 12, 2018 | 03:54 PM
oldbrokenwind
Unless you have your own tuning capabilities, there will be other tunes required for added mods. Or does SCS provide unlimited tunes?
I haven't checked the Manic website, other than to see it changed from a year ago. The way I heard it from my tuner was he's only doing custom tunes --- datalog then new program, probably back and forth a couple times 'til it's good on a dyno and the road. This for stages 3 & 4. I would expect stages 1 & 2 to be pretty much canned.
I should be getting the head back in a few days, then re-assembly starts. I'll post it in NAM's new "Build" section.
Old Dec 12, 2018 | 04:39 PM
BigBoost's Avatar
BigBoost
Just like any other standalone they
give you a base map just to get you running
then the tuning is up to you
give ya a little look of the
program
Old Dec 12, 2018 | 04:47 PM
knt's Avatar
knt
£1,650.00
£720
to the us market
just
£720 is for the Manic Motorsport stage 3 remap.
I already have stage 2 remap and don't fancy paying £720 for stage 3 + £??? for stage 4, so might as well go for standalone ECU SCS Delta as the tuner can do a remap for £300.
With Manic maps we're probably paying too much anyways, as Manic takes a cut and the tuning shop takes a cut.
Old Dec 12, 2018 | 04:53 PM
knt's Avatar
knt
program
Thanks.
I'm sure the tuner I'm using will be more happy with tuning the SCS Delta ECU than the standard ECU.
Do you know if other tuning software is compatible with the SCS Delta ECU?
Is the software similar to the Link tuning software?
Old Dec 12, 2018 | 05:51 PM
oldbrokenwind
Just took a look at the SCS web site. From what you say above, and the site info, we get a base map (250-320BHP?) and a replacement ECU, not an additional unit to plug in alongside our OEM ECU. In my case, I also need a Windows PC or laptop --- their SW isn't compatible with a Mac. I also don't have a JCW MAF or MAP (forgot which). Then I gotta learn how to program the various features available on their unit --- that or find someone local. Unfortunately, I don't know squat about timing, fuel mixing, etc. and I'm getting too old to want to learn, so it'll be a job for a tuner. No way I'm gonna do trial and error!
My current tune should be good for another year or so, before my next upgrade. I'll sit tight and wait for others to get experience with SCS. Gotta admit tho, it looks promising. Maybe someone will use an SCS unit to break into the 400WHP domain.
Old Dec 12, 2018 | 06:07 PM
BigBoost's Avatar
BigBoost
400/450
there a few people doing it already
with a big turbo's
running stock ECM
Lohen last dyno day
had one
pretty positive it was a n14 as well
there a few down sides to the scs program
living tune is a pain in the ***
an it freeze
alot like alot
all the time
an yes will need a windows laptop
Old Dec 13, 2018 | 02:58 AM
knt's Avatar
knt
I'm not attempting to remap the car myself, as any decent tuning shop should be able to adjust to the new software easily and not mess around with unlocking and locking of the standard ECU, as I've heard that's the most difficult part and not the tuning itself.
Most tuning software I see people use run on windows, people with macs could use boot camp or virtual machines of windows.
Old Dec 13, 2018 | 03:03 AM
knt's Avatar
knt
400/450
with a big turbo's
running stock ECM
Lohen last dyno day
had one
an it freeze
alot like alot
all the time
Once rebuilt and forged, my target is 300bhp as my daily driver and make it last for another 10 years or so.
Old Jan 10, 2019 | 03:34 PM
knt's Avatar
knt
Hi,
Just got a message from RMW
"yes, it's ready for sale
the E85 will be ready shortly
currently it's only for N14s"
looks promising.
Anyone knows any more?
Old Jan 10, 2019 | 04:22 PM
BigBoost's Avatar
BigBoost
honestly I don’t think much of anybody’s heard anything
I just popped over to their Facebook
Last time they posted was
October 30
The last time they posted anything
About a standalone was
june 28
just check out the forums
an i was the last person
to post in the r56 tuning section
asking for lunch control
that was 12-18-2017
the only response I got was yes just a few mouths out
honestly I would not be holding my breath
But who knows
would be cool if they did come out with something
We need more performance oriented stuff
For the R-chassis
co0p3r
Jan 30, 2017 05:38 PM
soccerbummer1104
Jan 24, 2015 05:14 AM
ThePenl
Dec 30, 2014 12:02 PM
papawhiskey
Jul 3, 2014 02:11 PM
