F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Activation of rear fog lights
Old Nov 28, 2018 | 07:40 PM
flyinguy2000's Avatar
flyinguy2000
I have a 2016 Clubman S and it appears to have the wiring and bulbs in place for the rear fog lights. I do jot have the button however. Has anyone changed the switch on the left of the steering wheel and successfully activated the rear fog lights?
Old Nov 28, 2018 | 10:46 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
https://www.northamericanmotoring.co...rcode-app.html
Old Nov 29, 2018 | 10:12 AM
flyinguy2000
Thank you for the link. I'm not familiar with coding So I would need to find some help with that. Do you know if I buy the new light switch assembly that has the rear fog light switch if it will work once coded? It looks like everything is wired in the back. I'd hate to spend a couple hundred on the switch and find out it's not wired all the way. Thanks!
Old Nov 29, 2018 | 10:18 AM
Minnie.the.Moocher
I haven't read of anyone buying the switch and failing at the process. The coding with the Bimmercode app is very simple and I recall without reading that thread that all the info you need is in it. If you really need help you can pay someone on line to link with your car (not cheap) or find someone local. Post up where you are and maybe someone here will help you out for a cup of coffee or a beer or two.
Old Nov 29, 2018 | 02:33 PM
flyinguy2000
Thank you Minnie. I am in the Portland, Oregon area. I'll do some more reading about Bimmercode and what that means exactly. Thank for the help and I'm open for any help from someone out there.
philwarner
Nov 12, 2024 08:16 PM
Mister Spice
131
Jan 18, 2023 09:13 AM
jochummf
R60/R61 Stock Problems/Issues
Nov 7, 2018 03:03 PM
cristo
Nov 4, 2018 02:36 PM
carpecervisi
Electrical
Oct 23, 2018 07:12 PM
