R55 Mini clubman latch
Old Nov 25, 2018 | 01:10 PM
avbrummie's Avatar
avbrummie
Mini clubman latch
2010 mini clubman right rear door latch.
I took out the latch and tested the locking mechanism with a small piece of rod and it doesn't lock automatically.
Am I to assume I need to buy a new latch ?
Old Nov 25, 2018 | 02:39 PM
I like mini clubman's's Avatar
From reading other posts it appears to be a problem area for clubbies. Someone with more knowledge hopefully will chime in. Try the search and see what you come up with.
Old Nov 28, 2018 | 07:30 PM
EdsNotHere's Avatar
EdsNotHere
If you have a latch that’s not working I’d replace both latches to avoid it not opening and then it’s a PIA to get open when the latch fails. I replaced both of mine when the left one failed.
Old Dec 1, 2018 | 02:23 PM
mrbubba's Avatar
mrbubba
My left side one has stopped working, although it coincides with the fuse box being replaced and also the rear wash wipe not working
Old Dec 3, 2018 | 10:38 AM
Yep do both at the same time, these are the two threads you need to do the job:
https://www.northamericanmotoring.co...arn-doors.html
DIY:
https://www.northamericanmotoring.co...4-clubman.html
Old Dec 11, 2018 | 10:43 AM
CA94960's Avatar
CA94960
Today my wife tried to close her right rear door and it wouldn’t latch, so she called me to help. I arrived and tried to get it to latch, but the door would not lock closed. I got some string for a store and tied it up so she could get home. Anyone have this problem before?
Old Dec 12, 2018 | 08:27 AM
Did you manually do it with flat head screw driver on the mechanical latch side to test it. Using the screw driver as the fake striker hook.
Old Dec 12, 2018 | 08:47 AM
CA94960's Avatar
CA94960
I took it to our local independent Mini repair shop that does all the work I don’t know how to do and they said the right locking sensor needs to be replaced. It should be repaired by this afternoon.
Old Dec 12, 2018 | 08:52 AM
Ok, let us know how it works out.
Old Dec 12, 2018 | 09:08 AM
CA94960's Avatar
CA94960
Thanks!
It’s my wife’s car and she needed to have it repaird by tomorrow so she can take it to work. She didn’t feel comfortable leaving it in a parking lot with velcro strap holding the doors closed, hence the quick need to have it repaired.
Svejk
Feb 24, 2019 12:18 PM
Ministrater
Oct 2, 2018 08:31 AM
Zommski
Jun 19, 2018 08:50 AM
AutoMutt
May 11, 2017 12:35 PM
Spank
MINIs and Minis for Sale (archive)
Feb 16, 2008 11:39 PM
