PS pump noise when accelerating?
Old Nov 14, 2018 | 10:38 AM
perucho's Avatar
perucho
Hi Everyone. I have a 2006 MCS with 40k miles that has a loud noise when turning, but only when accelerating. If the car is idling, I can turn the steering wheel left and right without any noticeable whine. If I turn the steering wheel and accelerate, it has a loud whine. I can only hear the sound (it's loud) when stopped and starting to move while turning. I'm not sure if it's a belt or the PS pump. Any ideas? Thanks!
Old Nov 20, 2018 | 08:11 AM
Tgriffithjr's Avatar
Tgriffithjr
I assume you have checked the fluid level? If the pump is going out I wouldn’t think it unusual for pump noise to increase upon increased demand on the pump when accelerating. It is unusual that it doesn’t make noise at idle, except that possibly the pump is able to keep up under a reduced load.
Old Nov 20, 2018 | 10:29 AM
ItsmeWayne's Avatar
ItsmeWayne
It is important to only use the correct fluid, Which is pentosin CHF 11S. You can get it from Car Quest, Amazon, etc.
Do not ever mix with others!
Old Nov 20, 2018 | 10:39 AM
perucho's Avatar
perucho
Thanks for the responses. Fluid level is between the cap marks and is 11s. I'm almost certain it is not the PS pump. I can hear the pump when the car is running, at idle, and I turn the steering left and right. Not a loud noise and it get a bit louder (not much) when turning the wheel stationary. Also, if I press the accelerator a bit and raise the idle (car still stationary), and turn left and right, the PS pump sound is the same as the previous scenario. However, if in gear and moving, I can hear an rpm-dependent sound, only when turning and accelerating at the same time. If I'm coasting (off the gas) and turn, no noise; if I accelerate while turning, I can hear the noise. Almost like a belt noise, but the pump is electric.
Old Nov 20, 2018 | 06:12 PM
Tgriffithjr
It’s going to be hard to help you with only written descriptions of sounds. If there is no increased effort when turning or jerky feeling when turning then your pump is probably working. The only thing I can think of that would whine is the pump. A bad belt would squeal. You might try raising the front wheels off the ground and duplicate the conditions you hear the sound. Turning right and left accelerating and not accelerating.
Old Nov 20, 2018 | 06:34 PM
perucho's Avatar
perucho
Yeah, I guess it's hard to explain how it sounds exactly. I tried taking a video, but the phone doesn't pick up the sound well. I'm sure it's not the power steering pump. Thanks for the help though. Will keep digging.
Old Nov 20, 2018 | 06:36 PM
perucho's Avatar
perucho
Originally Posted by Tgriffithjr
... You might try raising the front wheels off the ground and duplicate the conditions you hear the sound. Turning right and left accelerating and not accelerating.
thanks for the idea, but that won't work. If the car is not moving, I can turn the wheel while accelerating or not, and it won't make that sound.
MiniFoot
16
Sep 21, 2012 01:23 PM
mini_racer
Mar 26, 2008 11:22 AM
PepperWhiteR56
Mar 21, 2007 05:21 PM
SeaMonkey
Jun 11, 2004 10:27 PM
XAlfa
Sep 20, 2003 08:31 PM
