R50/53 Code PO138 for 2005 MINI Cooper S
Old Nov 5, 2018 | 07:33 AM
Buggy's Avatar
Buggy
I have a 2005 MINI Cooper S with 125000 miles. Got a service engine light and my code reader kicked back a code PO138. Seems like I need to replace the number 2 oxygen sensor. It has never been replaced before. Was wondering if an aftermarket sensor on Amazon ($28.79) is sufficient enough quality vs. dealer part ($250.00) ? Also, should I buy a rethread tool to "clean the treads" after I remove the old one? Also, it looks very easy to replace by the YouTube videos I have watched, any suggestions before I start the job?
Thank you in advance !!!
or is it not necessary?
Old Nov 5, 2018 | 08:25 AM
DamnCampers's Avatar
DamnCampers
From what I understand the post cat O2 sensor is not as finicky as the pre cat O2 sensor. That being said the most reliable seems to be the NTK/NGK sensor then the BMW part. When I replaced my sensors I went with the NTK/NGK sensors as i found them for $110 each from Summit Racing.
Old Nov 5, 2018 | 10:37 AM
JAB 67's Avatar
JAB 67
I think they are less than that on RockAuto.
Old Nov 5, 2018 | 12:50 PM
DamnCampers
Yes you can find some brands for less then what I paid for the NTK/NGK O2 sensors. I was replacing both sensors and the pre cat sensor is the more picky sensor. I replaced both at the same time so I was worried more about direct fitment.
If you replace the pre cat sensor then the only two that are recommended to be trouble free are the NTK/NGK and BMW. Most others seem to be a crap shoot and generally throw some codes.
Old Nov 7, 2018 | 07:29 AM
Buggy's Avatar
Buggy
Old Nov 7, 2018 | 01:49 PM
beken's Avatar
beken
Nicely done. Congrats.
Old Jul 8, 2019 | 04:17 AM
Paul Giraldo's Avatar
Paul Giraldo
Just got this code on my way to work, hit Amazon for the part listed above and found one for $19 same part number and everything but doesn't specify upstream/downstream. The $28 item specifies downstream. I ordered the $28 sensor just because but I am curious, are they interchangeable?
Old Jul 8, 2019 | 09:30 AM
DamnCampers
Yes the sensors are interchangeable between locations.
05 Mini Driver
Sep 10, 2016 07:23 AM
bluemax61
Jun 26, 2016 09:14 AM
NathanMckee
May 11, 2016 04:46 AM
scottab36
Mar 21, 2016 08:38 AM
portedbuckle
Jul 16, 2015 06:10 PM
