I'm just gonna ask
I'm just gonna ask
I searched and searched and searched but couldn't find a definative answer...
I'm looking to run 17X7 with et40, the question is will 225/45/17 fit?
To note, we are not lowered and do not plan on lowering... i saw posts that said yea it will fit and others that said it would rub like no tomorrow...
please help
please help
^^^honestly and no offense; I don't buy it. If you look on the inside of the wheel arches, you will see at least a tiny bit of rubbing marks and/or melted spots of plastic where the tire hits the "spats" on big bumps.
Yes every MINI is a bit different, however it's math, not magic. With slightly corrected camber, I've seen stock 205/45-17's on s-lites with no spacers (ET50 fyi) rub the rear spat. I've also seen on a different MINI, a 215/40-17 kumho mx (very square and wide for its size) on a 7" et37 setup with very minimal melting. So going from that - a tire that's wider and taller will hit the spat sooner, and more of it. 3mm offset change will negate the effect slightly, but it'll still rub. Not that rubbing is a bad thing - but a 225/45-17 will be a quite snug fit. I'd be more apt to run a 235/40-17, which is much wider, but also shorter. You'll no doubt have to hog out the wheel arch, but whew that would be a wide tire for the MINI!
please help
please help
I have a lowered MCS with 215/45-17 and I rub a little in the rear wheel wells. I have checked a similarly lowered MCS with 215/40-17 and he rubs a little. Neither is enough to pull out the dremel.
So in your case if you don't lower your car you will likely rub but maybe not all the time if you happen to be lucky and not weigh too much. Put in a few people and go over some bumps and you WILL rub.
225/45-17 will fit the rims just fine. If you have lowered your MINI then have the dremel ready in hand.
It's your call, the 215/45-17 is a better choice than the 225/45-17 in my opinion. 10mm will save you the bother of rubbing and subsequent cutting.
It's functional and looks good. Tire selection is fairly decent as well.
I'll have to look
Kev....if you are really looking to get 17 x 17 ...just make sure the off set is right...that's the big deal for inner rubbing...as for turning the car...I am not sure that would work...due to the width of the new wheel...wide body kit?...heh he
I run Kuhmo MX'es 225-45-17s on enkei RPF-1s "43mm offset the only time they rubbed was in the rear with 4 adults in the car and on a bad dip in the road
Not that often I have 4 adults in the car! I drive the car hard and like the mx'es much better than the run-flats and the look great under the car.
Camden90240
Sep 28, 2020 12:09 PM
