Problems at higher acceleration
Old Oct 19, 2018 | 01:12 PM
redlinealley's Avatar
redlinealley
Problems at higher acceleration... Perform engine De-Carbon Procedure
09 MCS... Cruising on the highway at 70mph and a 18 wheeler hanging out in the passing lane. I stomp on the gas to go around him and hit 100mph, but with the car bucking and check engine light flashing on and off. Then I smell something like a bad catalytic converter fumes coming into the car.
I slowed back down to 70mph and everything is fine. Check engine light is off, smell went away and drives normal.... Could it be a blocked Cat or is there something else wrong...
Old Oct 20, 2018 | 01:53 PM
redlinealley
I romped on the gas again and got the check engine light to stay on, yeah.... So I went autozone yo get the codes read. Code P0300 multiple random cylinder misfires. There telling me the car needs a De-Carbon cleaning. Does this mean the valves need cleaning?
Old Oct 20, 2018 | 02:07 PM
DneprDave's Avatar
DneprDave
Yes, that what he means. Your car needs to have the intake valves walnut blasted. If you already have an air compressor, you can buy the tools necessary to do this yourself, for less than it costs to have it done.
Old Oct 20, 2018 | 02:12 PM
redlinealley
Yes I have a pancake 6gal compressor. I was looking into doing this, but the guy I bought the car from told me he just did a valve job on the car. I guess I'll have to take the intake off and look for myself.... Thank you for confirming the walnut blasting. Is there a kit I can buy or do I have to buy parts from different companies
Old Oct 20, 2018 | 04:21 PM
DneprDave's Avatar
DneprDave
That little compressor may be too small, it may work , but it will take a long time to get the valves clean.
I bought my tools from Pelican Parts. Here is their how to page.
https://www.pelicanparts.com/techart...n_Cleaning.htm
Old Oct 20, 2018 | 04:42 PM
redlinealley
Thank you!
Old Jan 12, 2019 | 08:52 AM
redlinealley
Walnut blasting intake valves and new coils solved the problem...
MiniSnoop
May 13, 2013 01:16 PM
Amytheallen
R55 :: Clubman Talk (2008+)
Aug 18, 2012 08:52 PM
Autoxser1975
Jun 12, 2011 02:27 AM
kjmurphy
18
Aug 10, 2008 11:02 AM
joshua
Mar 2, 2003 02:40 PM
