r56 rear creaking resolved
Old Oct 17, 2018 | 03:00 PM
2cati's Avatar
2cati
Earlier this year I had a subtle clunk so I replaced the rear endlinks and rear say bar bushings. Over time there was creaking from the back that started and got louder.
This morning I unloaded the rear of the car (both sides jacked up) wheels removed, endlinks disconnected - it was clear the creaking was coming from the rear sway bar bushings .......I just replaced them in May...I installed the new ones from the dealer, no squeaking....
I'll post a video of the squeaking rear sway bar bushings...
I may have purchased these Febi rear bushings from Amazon - I'll post pictures as well.
Old Oct 24, 2018 | 06:21 AM
2cati's Avatar
2cati
Man on man. I guess I bought the rear bushings off amazon really cheap. They worked fine for a while but I suspect the hole was smaller diameter than the oem bushings. I just bought them from the dealer as they aren’t that expensive. Now it is quiet!!
I suspect the ones off amazon were inferior rubber quality
the one on the left is the amazon one and the one on the right is the oem one from the dealer. Too bad I can’t upload the video. It clearly demonstrates the annoying sound.
Old Oct 10, 2019 | 04:14 PM
Frixos's Avatar
Frixos
Do you know if you actually got real febi ones from Amazon? I just ordered the febi bushings from ECStuning. I thought they are considered a quality brand?
Old Oct 10, 2019 | 07:35 PM
2cati's Avatar
2cati
They were advertised as Bistien-Febi....
As I mentioned, I regiment just getting from the dealer as they are inexpensive. In the end my cheapness cost me Time as I did the job twice....
Old Oct 11, 2019 | 05:48 AM
mini-is-for-me's Avatar
mini-is-for-me
Can you please post the video to Youtube and just give us a link to the Youtube video. I feel like I have this sound?
I bought a used 2011, 64K but it looks like it was driven on a lot of country dirt roads. The shocks also feel worn but still have a bit more life in them because I can still feel they provide descent support. So I was trying to figure out what it was. It sounds like something is "loose" in the trunk but different from shock noise. Just ordinary road cracks kind of make a "double sound". Is there any way to "inspect" them without disassembly? How much are the OEM compared to Amazon?
They look dirt cheap where shipping is the primary cost. https://www.autohausaz.com/pn/130178...UaAo5XEALw_wcB
Old Oct 11, 2019 | 06:09 AM
Frixos's Avatar
Frixos
I bought a used 2011 but it looks like it was driven a lot of country dirt roads. The shocks also feel worn but still have a bit more life in them because I can still feel they provide descent support. So I was trying to figure out what it was. It sounds like something is "loose" in the trunk but different from shock noise. Just ordinary road cracks kind of make a "double sound". Is there any way to "inspect" them without disassembly? How much are the OEM compared to Amazon?
I ordered two Febi on ECStuning for like $4 for both, as opposed to $20 for two original.
Old Oct 11, 2019 | 06:58 AM
mini-is-for-me
2cati is saying they are not as good and have problems over the OEM's. Did you have problems with yours? How difficult of a job is this to do?
It looks like mine for a 2011 would be different. 18mm
https://www.ecstuning.com/b-febi-par...556772788~feb/
over the 16mm
https://www.ecstuning.com/b-genuine-...r/33556754823/
I'm not sure if this is my problem yet.
Old Oct 11, 2019 | 07:05 AM
mini-is-for-me
Also, it kinda looks like these need to be installed with grease. Did you both use bushing grease?
https://www.ecstuning.com/b-powerfle...ease/pcg1~pfx/
Old Oct 11, 2019 | 07:07 AM
Frixos's Avatar
Frixos
over the 16mm
theyre coming in next week! I’m just gonna try and see how it goes.
it really isn’t hard from the videos I’ve seen. Take off tire, remove two bolts, replace bushing, reinstall two bolts, put back tire.
Old Oct 11, 2019 | 07:38 AM
Frixos's Avatar
Frixos
I haven’t heard that before.
i found this thread for whatever it is worth:
https://www.bobistheoilguy.com/forum...sway_bar_bushi
Old Oct 11, 2019 | 07:47 AM
Frixos's Avatar
Frixos
I just looked into the product details on ECS:
That silicone grease is for polyurethane bushings.
the sway bar link bushing is rubber. So I would think no.
Old Oct 11, 2019 | 11:13 AM
mini-is-for-me
So there is a youtube video for this? I took a look under there and it looks like an X so it is attached top and bottom on each tire? I guess you need 4 then, not 2?
Old Oct 11, 2019 | 11:16 AM
mini-is-for-me
So the sound I hear seems to be happening just constantly while driving and the best way I can describe it, is that it sounds like the rear lift gate is not completely shut and so the smallest bump makes a creaking bump sound.
Frixos's Avatar
Frixos
there are two of them total for mine:
https://www.realoem.com/bmw/enUS/sho...diagId=33_1358
check your model if it is different.
I found this video to be helpful:
Old Oct 11, 2019 | 11:19 AM
Frixos's Avatar
Frixos
that is also what mine sounds like! But I’ve checked the tailgate and have verified that’s not the source of the noise.
Old Oct 11, 2019 | 01:37 PM
mini-is-for-me
Yeah, no way it is the lift gate because that closes solid. Also,you can tell it is slightly lower than the lift gate....like the tools at the bottom of the hatchback. Now, I suppose it could be that and I can try and remove those to see if it changes anything.
mine looks like this>
https://new.minimania.com/Mini_Coope...e_Control_Arms
What am I trying to fix?
Old Oct 11, 2019 | 05:10 PM
JB160's Avatar
JB160
Check Upper shock mounts. They can cause this noise if worn or slightly loose. Chased this issue on my 2007 R56 for some time before installing powerflex mounts. Problem solved.
Old Oct 11, 2019 | 05:56 PM
Frixos's Avatar
Frixos
I just had them the upper shock mounts replaced back in May with lemfordelar. Could they have been installed too loosely?
Old Oct 12, 2019 | 06:21 AM
mini-is-for-me
https://www.youtube.com/watch?v=S3DIp9DMSVg
Good short video. That looks easier than the Pelican Parts method. He only has a short snippet of the sound but that sounds like the sound.
Old Oct 12, 2019 | 06:28 AM
mini-is-for-me
The Bushing looks like a cheaper and easier fix to start with according to that video. I shined a light up there and I can see the rubber is dry, hard, cracked and basically looks done. The bushing clamp and bolts have a lot of rust on them so it needs to be taken out, derusted, primed and repainted. My biggest fear will be the threads or heads are rusted off the bolts. I hear this sound without even going over a noticeable bump. I looked at the shock and I can see the top of the shock is not touching the body. The driver's side shock looks like it is in very good condition. The passenger side doesn't look as good. However, both look better than the front shocks. My plan is to replace the front shocks the same time as the brakes and the rear shock the same time as the rear brakes. Front brakes are nearly worn, <8000 miles left on those is my guess.
Old Oct 12, 2019 | 06:41 AM
JB160's Avatar
JB160
Fixros, If the shock mounts were not tightened enough, or have loosened a bit this could be the issue. I had 1 of mine start making some noise after installing the powerflex shock mounts. Had to remove an re-tighten. The least amount of movement in that upper mount will cause a rattle/clunk noise. Some mechanics I know advise using an impact wrench to tighten sufficiently.
Old Oct 12, 2019 | 07:21 AM
Frixos's Avatar
Frixos
which one? #10 bolts or #12 nut?
https://www.realoem.com/bmw/enUS/sho...diagId=33_1357
Old Oct 12, 2019 | 07:31 AM
cristo's Avatar
cristo
Alliance Member
#12 nut. And don’t use an impact wrench
as spinning the shaft is not good for
the shock. Hold the shaft with an allen
and use a thin walled offset wrench
or 1/2 inch drive socket with the
allen up through it or one of the
special sockets with an opening in their
side to tighten the nut.
#10 bolts are pretty easy to torque
properly and snugly.
Old Oct 12, 2019 | 07:35 AM
JB160's Avatar
JB160
Number 10 are the 2 bolts that hold the rear shock/ Mount assy. to the body. Number 12 is the nut that holds the mount assy. to the shock itself. This is the nut I was Refering to.
Old Oct 12, 2019 | 07:38 AM
Frixos's Avatar
Frixos
Thank you cristo and JB160!
I had this installed by my MINI guy in town, who usually does real good work. My plan is to change the bushings since they are already en route to see if that fixes it.
Would it be worth bringing it by the mechanic to ask them to check their work/diagnose the noise?
