Squeaky Clutch Pedal
2006 MCS
When I engage the clutch it squeaks like a cable or something is dry and it's a bit annoying.
Where do I lubricate the cable?
What sort of grease should I use?
As has been answered, it is hydraulic clutch with no cable. I suggest you listen to it carefully with the engine off to pin point the source of the noise. It could be the bushing for the pedal pivot but most modern car has plastic bushings which less prone to squeak. It could be the clutch mechanism in the bell housing, which can be bad news for you. With a helper would simplify locating the source of the noise.
...but at the moment that issue is on the backburner because I still have the bubbles in coolant issue. I haven't been driving the car much at all and count myself lucky that the fans are working properly and it hasn't exceeded 110C.
I've replaced the thermostat + housing, and the radiator.
This week I'm off work and currently waiting on parts so I can dig in and change the water pump as I strongly suspect o-ring failure --- while I'm there I will do a s/c oil service, new crank sensor o-ring, new tensioner + belt, and new major hoses.
sorsha6
Jun 13, 2019 06:00 AM
FlzRider
Sep 13, 2011 08:47 PM
