R56 R56 AT to MT swap prep.
Old Aug 22, 2018 | 07:23 PM
GT350's Avatar
GT350
I plan to take sometime in Sep/Oct to do engine & trans swap on my 07 R56. The car has auto trans, N12 engine has 2 bent valves. Bought a part car with N12 only 50k miles & a manual trans. I have searched everywhere online & visited couple of dealerships, can't find anyone did AT to MT swap. I want to list things that have to be swapped, if anyone had experience or did research, please help me prepare for the swap.
Parts required to swap transmission:
- Transmission (flywheel & clutch)
- Shifter
- Wiring harness (not sure which specific?)
- Brake master cylinder reservoir (interchangeable)
- Axles
- ECU
- Clutch & brake paddles, clutch master cylinder & clutch line
- MT radiator
what's more?
Old Aug 28, 2018 | 07:33 PM
MiniToBe's Avatar
MiniToBe
- Coolant pipes (maybe 2 or 3)
- Wiring (for clutch sensor, transmission reverse light sensor)
- you may keep the ECU otherwise you would have to swap the whole set ECU/CAS/keyfob and then you will get mileage anti-tampering indication dot next to the new mileage
- NCS Expert and NCSDummy to code the new configuration
- ISTAD to walk you though errors and way to fix issues (MUST HAVE.....Check my 08 clubman N18 engine swap project )
- https://newtis.info/tisv2/a/en/ To trace out wiring and make sure everything lines up
Old Aug 29, 2018 | 03:42 PM
GT350's Avatar
GT350
Thanks man, I knew you will put comments on this one. You were the only one commented my last thread regarding bent valves. I left mini behind couple months and worked on other cars, waiting for cool weather to work on it outside.
I checked your build project, nice job! I also got the nose from Hypermotoparts for my GP build. I guess we are not too far from each other. I live in central jersey.
Can you please help me understand a little bit more on your comments?
- I can swap the entire ECU/CAS/keyfob/tachometer. if the whole electronic system is swapped, why will it give me anti-tampering indication?
- what new configuration is required NCS codding?
- sorry, what is ISTAD?
Old Aug 29, 2018 | 04:00 PM
MiniToBe's Avatar
MiniToBe
Yeah brother im in philly right across the bond lol...
as you might know, the vin (and some also store mileage) is stored on every module in the car. So when you swap the "set" the instrument cluster and speedometer with read different and that will trigger the anti-tampering dot. The car will still start with new "set" but the mileage wont match or adjust.
If you also swap the instrument cluster/speedometer/Junction box/footwell module, then that dot wont show but the new mileage will be from the donor car.
Now, if you just swap the "set", you need ncs to tell the instrument cluster and the junction box that your running a manual tranny vs an automatic one.
ISTAD is an acronym for integrated service technical application diagnostics. Very powerful tool.
Old Aug 29, 2018 | 04:48 PM
GT350's Avatar
GT350
I can replace the whole set as long as they are all the same between the cars to avoid NCS, not interested in coding at all ... where did you learn all these things?
Old Aug 29, 2018 | 04:55 PM
MiniToBe's Avatar
MiniToBe
Yeah you could swap all of them and see what doesnt chime....i learned solo in the house and a bit i mean alot of trail and error...i paid $$$$ for mistakes i did too but now I'm comfortable working on it hence the n18 swap project
Old Aug 29, 2018 | 05:04 PM
GT350's Avatar
GT350
Thanks for sharing
Old Aug 31, 2018 | 04:53 AM
MiniToBe's Avatar
MiniToBe
Anytime Brother post some pix of the cars ....Where in Central NJ are you in? you might've told me before but i forgot.
Old Sep 1, 2018 | 10:26 AM
GT350's Avatar
GT350
I
I live in Hillsborough. Took a pic this morning, should work on it in couple weeks.
Old Sep 3, 2018 | 08:57 AM
GT350's Avatar
GT350
Spent 3 hrs this morning to check & remove the parts for the swap.
- Engine & Transmission: A lot easier than I thought. Engine harness has two main connections to the other harness. 1 is connected to the positive terminal from the starter, 2 is connected to the harness that goes through the firewall on the driver side. So no need to removal majority of the connectors in the engine. Haven't checked shift cable, but should be easy to remove.
Question: There are 2 lines go underneath the firewall, one is fuel line, what is the other one next to it?
- Pedal set: Removed clutch and brake pedal set, very straightforward. Removed entire dash to allow a lot of extra room. The brake master cylinder and reservoir are the same for AT or MT. The clutch master cylinder & lines that go through the firewall are needed for the swap.
- Wiring harness: This is what I found the most difficulty. There are 3 main wiring harnesses in the engine bay.
1. Passenger side through firewall - connects to passenger lights, horn, ambient temp etc.
2. Engine harness
3. Driver side through firewall - connects to driver side lights, windshield fluid reservoir, ECU (1 of the 3 connectors), fuse box, power steering, ac, etc.
There are several places I found are different between the two cars, which make me think I have to swap the entire wiring harness.
1. Both fuse boxes in the engine bay or passenger side footwell.
2. The donor car has fog lights
3. Clutch master cylinder (MT) & Automatic transmission control unit (AT)
Old Sep 3, 2018 | 10:32 AM
MiniToBe's Avatar
MiniToBe
The second line is for the gas tank ventilation.
you might have to splice the wiring related to plug 1 of the DME (this goes to inside the car and fuse box). Check/compare wiring and splice the difference.
Old Sep 3, 2018 | 06:08 PM
GT350's Avatar
GT350
I guess I can disconnect the quick-release fastener on the gas ventilation line?
Will spend some time this week to check the wiring.
Old Sep 4, 2018 | 06:26 AM
MiniToBe's Avatar
MiniToBe
you could do that...but make sure nothing gets tangled.
Old Sep 5, 2018 | 04:51 PM
GT350's Avatar
GT350
I am stuck... everything is already to remove or already removed except wiring. I checked Bentley manual, there are many electrical changes after car manufactured from/to12/2008. The part car is 03/2009, my car is 2007. My guess the only way is to buy & swap an entire wiring harness from a manual car produced prior 12/2008. Any thought?
Old Sep 6, 2018 | 03:33 AM
MiniToBe's Avatar
MiniToBe
Before you go nuts, go back to both wirings and see what changed. I know the 07 has the steering electric lock mechenism.
Separate the wires coming out of the driver firewall. I think there will be 4 groups:
1- ECU
2- ABS
3-transmission
4- Lighting.
I think you need to focus on 1 & 3 for now.
Look at the wiring on new.tis for that plug (ECU to inside the car) for both cars and see what the functions are for each pin. Then compare the two and make the change.
Old Sep 6, 2018 | 08:13 AM
GT350's Avatar
GT350
Got an idea after watching E46 AT to MT swap on Youtube. I went back to Bentley book and found all the pins that connect to clutch master cylinder & reserve light switch reads shifter position. Total 6 wires connect to #3 ECU cable, CAS & footwell module.
Old Sep 7, 2018 | 06:15 AM
GT350's Avatar
GT350
I am thinking through all the possible elements for the swap prior to taking actions. I have identify all the wiring diagram for clutch & reserve light switch, so one problem is solved. Another question came up last night, I plan to not to swap footwell module, DME or CAS. But CAS controls car start, one of the checks to start the car is AT has to be on P position, MT doesn’t require that cable to detect gear position. I assume CAS was programmed to recognize only AT for my car, so I doubt that CAS will allow the car start after the swap. The R56 & R55 have different CAS due to the electrical update by Mini for cars produced after 12/2008. So I am concern about the CAS swap.
Can CAS be programmed to recognize MT? I would also compare the CAS connectors on 2 cars and see if possible to rewire.
I know CAS pair with the key, should DME or footwell module has to be swapped with CAS?
Old Sep 7, 2018 | 06:23 AM
MiniToBe's Avatar
MiniToBe
for testing purposes, you could swap the DME/CAS/Fob to get the car started for now and read any codes it pops. Should you keep the originals on the car, you need NCS expert to code the car for the MT set up.
Old Sep 7, 2018 | 07:01 AM
GT350's Avatar
GT350
Can I keep the existing CAS and code it to MT setup? I will check NCS expert tonight.
Old Sep 7, 2018 | 07:37 AM
MiniToBe's Avatar
MiniToBe
you have to keep the whole set CAS and DME...and yes, you can code it for MT....best thing might be to copy the file from the MT CAS and then past it into the AT CAS. it can be done..that is the easiest part of the whole thing...lol
Old Sep 8, 2018 | 01:33 PM
GT350's Avatar
GT350
Update: clutch wiring to CAS & ground is complete. MT trans reserve light switch wiring to footwell module is complete. Clutch & brake assembly, clutch lines are installed.
CAS pin 41 connects to either gear position for AT or clutch position for MT, no other pin connects to transmission wiring. I hope the engine can start w/o coding.
Is it the 1st r56 has clutch pedal & Auto gear? lol
Wiring
Old Sep 9, 2018 | 09:21 AM
MiniToBe's Avatar
MiniToBe
Nice work...keep it up brother...you might be done before my engine swap
Old Sep 10, 2018 | 04:01 PM
GT350's Avatar
GT350
what is the issue for your swap? I should get it done in a week or two depends on the weather, but coding will be the one I worry about.
Old Sep 10, 2018 | 04:10 PM
MiniToBe's Avatar
MiniToBe
oh brother where to start...In short, I might developed a short somewhere in my wiring after I used a used (known to be good) fuel rail pressure sensor. Any ECU I put reads 61v for battery voltage. I have ordered few ones and they all read the same faults! even thought i have a missing crankshaft pos sensor, the car still starts!!!! check the post for more details....but it is killing me man...getting very close...
programming is the easiest thing. let me know when you get to that point and i'll help you out.
Old Sep 10, 2018 | 04:13 PM
GT350's Avatar
GT350
I saw your video, the engine sound normal to me. 61v, that is R56 record I guess
