Suspension R53 with Koni FSDs (Pictures Requested)
Old Aug 13, 2018 | 12:31 PM
azamjunejo's Avatar
azamjunejo
Hi guys,
After all the rave reviews (and my current busted suspension), I’m thinking of upgrading to the Koni FSDs. The one thing I’m hesitant of is that the height of my car will increase. Searching around, I’ve only found a couple of pictures showing R53s with Koni FSDs installed. I was hoping some of you with the same set-up would share side profile pictures showing the height. Thanks in advance!
Old Aug 13, 2018 | 01:05 PM
Subw00er's Avatar
Subw00er
You have to use OEM springs with the FSD/SAS shocks. The height of the car shouldn't increase or decrease if you are not changing springs. Springs define the height, the shocks just control the dampening rate.
Old Aug 13, 2018 | 03:37 PM
azamjunejo's Avatar
azamjunejo
Completely understand that, but many have commented that the FSDs increase the overall height over the OEM struts.
Old Aug 13, 2018 | 04:36 PM
Fly'n Brick's Avatar
Fly'n Brick
I put them on about 5 years ago, R52 not much different than the 53, with no change whatsoever and wouldn't have it any other way. I'm getting a slight hint that your's may be lowered? If so, you need the yellows and not the FSD. Also, while you have it jacked up would be a good time to add a stiffer adjustable RSB either 19 or 22 MM. You won't believe the difference in handling. This is a 3 year old shot of our little guy somewhere on "The Loneliest Highway" so you can see there's no height difference..
Old Aug 13, 2018 | 05:49 PM
azamjunejo's Avatar
azamjunejo
Thanks for the pic! I currently have a stock set-up and am happy with the look and ride. From some the old conversations I read, I thought there might be some huge gap between the top of tire and fender.
Did you change your springs?
Old Aug 13, 2018 | 06:14 PM
Racingguy04's Avatar
Racingguy04
I've had FSD's with stock springs for a couple of years and I haven't noticed any difference in ride height.
Old Aug 13, 2018 | 07:18 PM
Fly'n Brick
Negative. Everything on the suspension is OEM except for the dampers and RSB.
You will greatly appreciate the difference in handling with the FSD and RSB upgrade.
Old Aug 14, 2018 | 05:20 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
if someone said the fsd changes ride height, they were wrong, shocks do not change ride height, springs do
Old Aug 14, 2018 | 05:50 AM
Subw00er's Avatar
Subw00er
R52 may sit a little different than a r53; r52 use different springs due to the added weight on the rear end.
Old Aug 14, 2018 | 07:11 AM
MINI33342's Avatar
MINI33342
Dampers absolutely can raise the ride height. Most performance dampers are gas charged. They come with the shafts held in place for shipping and as soon as you remove the straps the dampers will extend to full length. As to the amount of difference, very little.
Old Aug 15, 2018 | 02:51 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
I think the reason for this is because people replace worn out parts and the car returns to it's original ride height. We install FSDs all the time and notice that high mileage cars that were all worn out do tend to stand back up. But not ever seen FSDs increase the ride height over stock.
We have FSDs in stock too
https://www.waymotorworks.com/koni-fsd-shocks.html
Old Aug 15, 2018 | 09:20 AM
MrBlah's Avatar
MrBlah
gas charged yes, but not pressurized against the piston like that. I can push FSD and Yellows down with my hand
Old Aug 15, 2018 | 11:27 AM
Subw00er's Avatar
Subw00er
yup.
Old Aug 17, 2018 | 10:01 PM
davisflyer's Avatar
davisflyer
Stock springs and FSD's
Old Aug 20, 2018 | 09:27 PM
Subw00er's Avatar
Subw00er
Anyone have fsd/sas with higher rate springs, but at oem ride height?
Old Sep 16, 2018 | 10:02 PM
Timbo14's Avatar
Timbo14
Stock "S" springs, special Actives
Old Sep 30, 2018 | 05:47 PM
HaltCatchFire's Avatar
HaltCatchFire
Just installed. This is after a couple sessions on the track to settle them. I'd say the height went up nothing in the front and about 0.25" in the rear, and that's because my foam mounts were well worn and I replaced them as well.
Old Oct 1, 2018 | 02:22 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I try not to put foot in my mouth, but here I try. The FSD should not increase ride height. Yes, after you put the dampers in, and lower the jack the ride height might increase because of stiction and stronger damping - if you didn't slam the car down fast.
mininutz
SCCA Solo and ProSolo
May 24, 2007 01:26 PM
trentf
Suspension
Jul 22, 2006 10:01 AM
ChiliCooperS
Suspension
Mar 16, 2006 04:43 PM
