Fuel pump not priming before start
Old Aug 9, 2018 | 06:41 PM
xcmtber14's Avatar
xcmtber14
I'm having sputtering, missfires and low fuel pressure for 20-30 seconds on start-up then full performance afterwords. This is after the car sits for 8 hours or more. I replaced the fuel pump and tested voltage to the pump. Looks like the pump is never getting voltage to "prime" either at door open or ignition on. When I start the engine I get full 13 volts to the pump. What would cause the pump not to get voltage to prime? After the hard starting, the car runs perfect.
Old Aug 13, 2018 | 03:26 PM
xcmtber14's Avatar
xcmtber14
No one has ran into this issue at all? Is there a possibility the DME has a fault and isn't sending the fuel pump relay a signal to prime?
Old Aug 13, 2018 | 04:06 PM
shanksamillion's Avatar
shanksamillion
Haven’t had this issue before. You could have a bad primary fuel pump. The pump primes when you open the driver door. Open the door and listen carefully for a little hum or buzz, That’s the system priming. If you don’t here that then that’s likely your problem. I don’t know how that primary pump works, or if there’s a fuse/relay that you can replace if system doesn’t prime when door opens. I just don’t know that part. You might have to replace the primary pump. Access is under back seat.
Old Jun 14, 2019 | 09:03 AM
English's Avatar
English
Did you ever sort this out
I’m having the same problem fuel pump not priming until startup
no prime or voltage when door opens, no prime or voltage when ignition is turned on.
only when the engine is turned over does the finely pump run.
when power is put to the fuel pump it runs, so fuel pump is fine.
i have tested the relay the black one at the bottom of the fuse panel inside the car and it clicks, I assume this is the fuel pump relay ? When I look on websites for the relay it shows a 5 pin relay but the one in the car is only a 4 pin.
the car was running fine until a couple of weeks ago so if this is the relay it should be the right one.
all of these minis seem to be different in someways either by models, engines or years
my mini is a 2011 Mini Countryman S All4
need help to figure this one out
Old Nov 2, 2019 | 11:43 PM
minigerm's Avatar
minigerm
Did you get this resolved?
We're having the same problem with our 2011 Cooper S hardtop. Car will not start. No power to the fuel pump with ignition on. Pump runs if we jump directly from the RH kick panel fuse block F46 terminal. WIres have continuity from connector at fuse block to connector at fuel pump. My understanding is that the fuel pump relay on models after around 2006 are soldered into the two-layer fuse block assembly. I've seen someone rig a new relay into the previous model with the fuse panel in the LH kick panel but nothing for these later models. Anyone have a solution for this other than getting a new fuse block assembly and having the dealer reprogram the car?
Old Jan 7, 2020 | 07:14 PM
brian silvan's Avatar
brian silvan
Was this ever solved? My 2009 won’t start. Pump comes on during crank but no prime. Fuse box replaced still no start.
Old Jan 8, 2020 | 06:34 AM
Yes, you should here a high pitch whine when you go to unlock the car, its the low pressure fuel pump. All i can think of is get the schwaben scan tool and see if it does pull a code, some codes come up without a check engine light as they are vehicle specific codes. My guess is the relay or the fuel pump itself is weak.
Old Jan 15, 2020 | 06:00 AM
edwkmho's Avatar
edwkmho
you should try check out this post - https://www.northamericanmotoring.co...rt-at-all.html
I had the same problem with my 2009 JCW it turned out to be a relay in JBE that drive the low pressure fuel pump which you are unable to replace. I got myself a new JBE and it started up right away.
The relay in question is K96(the black color relay - Hella 4RA 743 555-10). I am attaching some photos for your reference. Hope they help.
Old Mar 28, 2020 | 01:39 PM
brian silvan
I replaced the JBE with no luck starting. Not a complete loss because my once dead radio is back alive. After months of trouble shooting and failed attempts I replaced the HPFP, Mini started and LPFP primes again.
Old Mar 30, 2020 | 08:27 AM
Thats good to hear.
Calm_batman
Jul 23, 2024 11:16 AM
Supergreen03
Jan 21, 2023 12:29 PM
MidwayMountaineer
Jun 27, 2022 07:39 AM
TheBlur
Mar 21, 2017 12:09 AM
