Mini Code P2885
Old Aug 6, 2018 | 04:54 PM
uni's Avatar
uni
Mini Code P2885
I've got a P2885 with no limp mode. Occurs when accelerating hard. All threads I've seen describe the code accompanied with limp mode.
There's so many things this code could be but I would think since there's no limp mode it could be narrowed down?
Thoughts?
Car is 2007 R56 Turbo.
Old Aug 11, 2018 | 05:02 AM
MiniToBe's Avatar
MiniToBe
https://www.northamericanmotoring.co...ower-loss.html
Old Aug 11, 2018 | 06:23 AM
08miniS08's Avatar
08miniS08
Thoughts?
Start with the vacuum lines. They become swollen and need to be replaced over time. Is you car boosting properly?
Old Aug 11, 2018 | 12:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
There are many things that can cause this code so you will need to do some diagnosis, but many times we see it actually being the turbo waste gate worn out. If that's the case you will need a new turbo.
https://www.waymotorworks.com/stock-...8-r59-r60.html
Old Aug 11, 2018 | 02:56 PM
uni's Avatar
uni
Ok. Yeah it seems to be boosting fine. Will try some suggestions and follow up.
Old Aug 15, 2018 | 03:26 PM
uni's Avatar
uni
Thanks to 08miniS08 for figuring this one out. It was a vacuum hose, in particular the one to the waste gate.
Before when I would reset the code, it would come back at about 5-6k rpm (accelerating hard). Now, the code doesn't come back so I'm certain it was a the hose.
Old Aug 20, 2018 | 07:24 AM
08miniS08's Avatar
08miniS08
Good to hear. If it comes back, then check the vac lines under the intake manifold at the reservoir. Those can get swollen and come off as well. They are a PITA to access. You have to remove the manifold to get at them properly. If you do, just replace the entire vac lines ($65 part from the dealer) and manifold gaskets ($10 aftermarket part).
mini4tide
Nov 6, 2017 09:13 AM
SpuuDy
Dec 17, 2016 09:00 AM
Ladybug-S
Jul 10, 2015 02:23 PM
Black Sharpie
Apr 8, 2015 07:08 AM
Mini Coupe
Dec 31, 2010 07:01 AM
