Drivetrain Stage 3 Mini just threw a code! (p2885)
Old Dec 30, 2010 | 10:36 PM
Mini Coupe's Avatar
Mini Coupe
Okay, so I was just out driving with a friend who hasn't been in my car since I got my new parts, and I did a pull from the bottom of third all the way through the top of the gear (didn't hit 7000rpm redline) then after about a 30 second roll to sixth, a pull in sixth. After about a few seconds the check engine light flashed at me (only on the tach, not on the actual instrument panel) and on my navigation panel it said engine power reduced. So I took it slow back to my house about a mile away.
When I got there I sat in the driveway and took out my accessport and read the engine codes. The code p2885 came up. Then all of a sudden the the front fan of the engine came on louder than I've ever heard it before and I immediately turned the car off.
I went online to find out what the code means, but I can't find it. So I waited about an hour, then went outside, deleted the code, started the car, and took it for a spin. Everything felt fine, no fault codes. Slowly built boost in different gears to test pressure. Then did a sixth gear pull from 1500rpm to 4000rpm and everything was okay.
Does anyone have any idea what that could have been? Thanks in advance fr your help!
Old Dec 31, 2010 | 07:01 AM
R56 Wi MINI's Avatar
R56 Wi MINI
read this thread:
https://www.northamericanmotoring.co...de-2885-a.html
Svejk
Feb 24, 2019 12:18 PM
ti22fjc
Aug 9, 2015 05:49 PM
pewx3
Aug 7, 2015 03:34 PM
