"Stuck" rear brake caliper bolt...how to remove?
Old Aug 6, 2018 | 09:31 AM
Ketchup's Avatar
Ketchup
Hi all.
2010 MCS. I have done the front brakes twice now and really easy to do. Tried to do the rears since they are getting low and the lower bolt for the left rear will not loosen so I didn't even try the others.
I am assuming the same "righty-tighty, lefty-loosy" applies to these bolts? I know they have some blue locktite on them.
Are there any tricks I can use to get it out? I bought a new 13mm closed-end and a new 13mm socket in hopes of getting a good grip on it...no luck. It started to round off the head. I didn't want to damage it further.
Please let me know if you guys have any tips.
Thanks a bunch!!
Old Aug 6, 2018 | 12:36 PM
Subw00er's Avatar
Subw00er
Soak them overnight in some sort of fluid. I hear brake fluid works well?! Hammer the socket on a little to make sure its on there good and support it while turning. Get a breaker bar and go easy.
Mine were actually stretched, so I replaced them. The sight of a stretched bolt is shocking. I was SOO happy they dint break off. Check this out:
Old Aug 6, 2018 | 04:11 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
2 Minute paint remover has the chemical that Loctite recommends for cleaning off the blue. Don't know if it penetrates the threads when in place. I used acetone to clean up the bolts I removed from other parts of my MINI.
Old Aug 11, 2018 | 09:37 AM
Ketchup's Avatar
Ketchup
Done!
I got a can of that "B'Laster Catalyst" and tapped the bolt a couple of times and easy peazy!!
I did buy the Irwin Bolt Extractor set, but didn't need it. Also got a cheapie brake rewind kit off Amazon...I love saving money! They wanted more than $600 for just the rear brake replacement!
Old Aug 30, 2018 | 05:50 PM
mattiemo's Avatar
mattiemo
If there is nothing around to worry about heat. (Which I am sure isn't a priblem) heat it good with a torch. If a torch is an option it's my first go to.
second being a good penetrating oil over night as a minimum.
Old Sep 2, 2018 | 07:32 PM
isamin's Avatar
isamin
P/b blaster
isamin
farside847
Tires, Wheels, & Brakes
Mar 24, 2019 08:26 PM
AzBluesman1962
Suspension
Aug 5, 2018 06:03 PM
Camber13
Jan 25, 2017 04:43 PM
indianainline
Nov 20, 2016 09:26 PM
edinamini
Jan 18, 2014 07:07 AM
