Help! Countryman rear brake caliper mounting bolt?
Old Jun 13, 2015 | 06:38 AM
Camber13's Avatar
Camber13
Help! I did the front brakes on the 2011 countryman S without difficulty. I'm trying to do the rears this morning and I can't figure out how to get the rear caliper mounting brackets off, which need to come off so I can replace the discs. They appear to be attached by some type of reverse Torx head nut on the inside of the trailing arm. It looks like I need some type of special Torx head socket to remove this nut? The brake disks won't come off without removing the mounting bracket, of course. Anybody know what size this is, where I can get one?
Thanks!
Old Jun 13, 2015 | 08:40 AM
Mib4840's Avatar
Mib4840
I do not know the size but if I remember correctly I have seen the tool you are looking for at Sears and Harbor Freight. You might call them and ask if they carry them. I also think they are called "external star" sockets.
Old Jun 13, 2015 | 11:22 AM
Camber13's Avatar
Camber13
Thanks! Turns out to be an E-torx socket, size 14. Works like a charm. In the end, a pretty easy job. Now i just need to figure out how to reset the brake warning light since i replaced the front and rear sensors as part of the brake job.
Old Jun 13, 2015 | 12:13 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
YouTube has several videos showing how, pretty simple!
Old Jun 13, 2015 | 02:09 PM
Camber13's Avatar
Camber13
Thanks, got everything reset without difficulty, working great! Thanks again for all the assistance.
Old Jan 25, 2017 | 04:43 PM
timic's Avatar
timic
Which tool is suitable to push back the rear brake caliper piston for 2012 Countryman base. I saw some on Amazon or eBay but not sure if they can fit or not.
squawSkiBum
Oct 2, 2015 09:21 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
StealthR53
Aug 8, 2015 10:59 AM
