2007 MCS Temp Sensor Signal Error
Old Jul 22, 2018 | 11:23 AM
GBugg's Avatar
GBugg
We pulled the motor to replace my daughter's clutch. Now we get a CEL showing code "2F19 - Coolant Temperature Sensor, signal".
I've changed the sensor and the connector (thinking I pulled a wire or something during the removal?) but no joy. The light comes right back on after clearing the code and the radiator fan goes to HIGH mode even when cold.
So...
1. What should I check/fix next?
2. Is it safe for her to drive in the meantime?
Thanks.
George
2007 Mini Cooper S
6 spd, manual
Old Jul 22, 2018 | 02:36 PM
GBugg's Avatar
GBugg
IF the "coolant temperature sensor" is the same thing as the "engine temperature sensor" referred to in my Bentley manual, pin 2 goes to ground (as indicated) but pin 1 doesn't connect to pin 32 in the ECU connector like Bentley says it should. The wire colors don't match (Bentley vs actual), so I'm wondering if they are 2 distinct sensors.
Old Jul 23, 2018 | 05:36 PM
ditc's Avatar
ditc
This may help. Had the same issue and dealer fixed it under warranty. But I understand there is a whole new type of temp sensor available. Not sure what the details are on that.
File Type: pdf
Old Jun 4, 2023 | 03:16 PM
aqibi2000's Avatar
aqibi2000
wish we knew what the root cause is . Have the same happening after fiddling with some connectors
orionwave1
Oct 13, 2025 05:36 PM
iXMrBulldopsXi
Mar 9, 2021 08:39 AM
ansan12001
Feb 5, 2021 10:17 AM
WifesMiniIsAlwaysBroken
Jan 14, 2020 04:00 PM
mejerry
Dec 26, 2015 02:07 PM
