Antenna base weatherstripping
Old Jul 21, 2018 | 02:34 PM
ericf1993's Avatar
ericf1993
Hi all,
i found out today that a piece of my weatherstripping around the antenna base has fallen off exposing some of the base behind the weather stripping. I was wondering if this is a reason to get a new antenna base or would i still be ok in terms of water getting in when it rains. I live in california so dont have to worry about rain for a while but i was just curious if the water can get to the inner wires this way. Thanks
Old Jul 25, 2018 | 07:38 AM
MiniToBe's Avatar
MiniToBe
Better to just replace it.
Old Jul 25, 2018 | 05:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
They don't offer the seal by itself as it comes with the antenna base
I have a good used one or two if need
Old Jul 25, 2018 | 08:42 PM
shanksamillion's Avatar
shanksamillion
How much for the used one? How much for new?
Old Jul 26, 2018 | 02:38 PM
ammodave's Avatar
ammodave
If it leaks, you're probably going to ruin your headliner with a water stain. Removing the antenna is a pain, You have to partially remove the headliner to get to the nut holding it on. If you try to remove it by just pulling the headliner down you'll probably end up with a permanent crease in the headliner under the antenna. You could always just make your own gasket out of vinyl or rubber if you're handy. Good luck.
Old Jul 26, 2018 | 05:02 PM
WayMotorWorks
Vendor
Used
https://www.waymotorworks.com/used-a...e-r55-r56.html
New
https://www.waymotorworks.com/antenna-base-r55-r56.html
cheezehead
Apr 14, 2017 04:44 PM
noodlesandsam
Nov 28, 2015 05:56 PM
TheGermanJob
Jul 27, 2008 03:05 PM
umberto
Apr 12, 2005 01:41 PM
tondu
Mar 6, 2003 06:48 AM
