Navigation & Audio Getting access to door speakers w/o removing entire door panel?
2009 MCS, aftermarket head unit and speakers.
I've had JL Audio C2-650 components in my doors for probably 8 years now. One of the drivers in my driver-side door is blown and I want to find out if its the woofer or tweeter.
Can I get access to the speakers without removing the entire door panel? Can I just pop out the grills/covers? If so, how is this done without damaging any clips holding things together?
To access the tweeter, you don't need to remove the door-card. Just get a plastic pry tool and gently pop off the speaker grill.
To get access to the woofer, you'll have to remove the outer door panels.
Removing the entire door-card assembly is extremely easy and just requires a plastic pry tool and some gentle tugging. It's just held on by plastic clips.
PelicanParts has a very good write-up with lots of high-res pics.
teinesina
Nov 1, 2014 09:19 PM
Navigation & Audio Removing OBD Footwell panel to access X9331
noragrets
Aug 28, 2014 12:07 PM
Axion
Apr 27, 2013 08:17 AM
Navigation & Audio Removing Panel to Access Pass-through on Left-side of Center Stack
AnyMiniMineyMo
Apr 13, 2008 10:25 AM
