Drivetrain N18 intake tube?
Old May 24, 2018 | 01:33 PM
sbninja's Avatar
sbninja
N18 intake tube?
Hello all, I am considering upgrading my turbo. Currently at a Manic stage 2+ tune.
​​​​​​I would like to get a forge intake tube to. What are you all using? I see that the forge has one provision for a ancillary tube so I can connect to the to the valve cover but not one for the other tube?
What are the electrical connections on the factory intake tube?
Old May 25, 2018 | 03:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If I was going to do it all over again, I would get an NM intake - the one that replaces the turbo inlet tube. The NM is the only one that provides resistors for the two heater elements, and provisions for all the vent tube connections.
Old May 25, 2018 | 03:50 AM
sbninja's Avatar
sbninja
Thanks . I didn’t know tha NM makes an intake with all the provisions. I have only seen photos that only have 1 vent tube. Are these just old photos on their website?
Old May 25, 2018 | 04:45 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes they do! It is a little pricey, but seems worth it to me.
Here you go:
http://www.nm-eng.com/291/0/0/2965/n...induction.html
Old May 25, 2018 | 01:24 PM
sbninja's Avatar
sbninja
Thank you njaremka!
Old May 28, 2018 | 04:38 AM
4mikebruns's Avatar
4mikebruns
NAM Community Team
I bought the CTS Turbo intake and then called NM and they sold me just the resistors for the plugs. CTS sends you a resistor but its literally just a regular wire one that doesn't have the Male plug on it like the NM lol
Old May 28, 2018 | 05:23 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Do you know what the resistor values are?
Old May 28, 2018 | 05:25 AM
4mikebruns's Avatar
4mikebruns
NAM Community Team
No I dont. It was a while back. I didnt even attempt to use it. It's not that much though.
Old May 29, 2018 | 10:05 AM
SeveNx7's Avatar
SeveNx7
I paid like 25.00(Give or take a dollar) to NM for the resistor packs and my check engine light should go away!
They call it the PCV heater delete kit I belive.
Old May 29, 2018 | 10:31 AM
4mikebruns's Avatar
4mikebruns
NAM Community Team
that's what I did too lol
Old Mar 20, 2019 | 04:02 PM
Zachary Nguyen's Avatar
Zachary Nguyen
Do you guys know if the NM provided resistors will work with the Forge Silicone Inlet hose? I'm thinking about going that route to save money for now and can pick up the NM intake later and attach it to the forge hose. I know the NM induction is the ideal solution but a bit pricey.
Old Mar 20, 2019 | 04:16 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The resistors will, but you still have to figure something to do with the small vacuum tube that comes off the side, too
Old Mar 20, 2019 | 04:31 PM
Zachary Nguyen
Ah I see. So looks like stock or NM induction are the only full no fuss solutions when it comes to the turbo inlet. May just save up for the NM then
Old Mar 20, 2019 | 04:37 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
If you are going to call NM and see about buying the resistors, see if they will sell that PCV use adapter with the smaller side tube...
TazMinianDevil
Aug 13, 2014 03:41 PM
ROOSEY
Jun 3, 2013 05:12 PM
Dead Ringer
R55 :: Clubman Talk (2008+)
Nov 21, 2008 09:40 AM
joshK
Jan 1, 2008 11:01 AM
