other cars with the same bolt pattern?
The reason I'm asking is I bought some after market mags/snow tires (205/15/60),but my MCS is lowered (Eibachs) and there's a slight rub in the rear when doing "spirited" driving in the winter. What other car has 4X100 bolt pattern so I can advertise them?
here's a site with info on bolt patterns and centerbore for tons of old
and new cars: http://www.prestigewheel.com/HubRingsbyMake.asp .
Some Hondas and Acuras and Subarus have 56.15 mm centerbore in
their 4x100 cars.....essentially same as the MINI. BMWs, VWs, Saturns,
and Audis have 57.1 mm, Toyotas, Mazdas and Suzukis have 54 mm,
and Nissan has 59.2 mm, to name just a few brands. For some wheels, you
can switch centering rings to the appropriate size. Then you need to
consider if the offset is appropriate (42-50mm).
You know what's wierd is that I tried to fit these Momo Wheels that came off of a 95 Honda Civic DX on to my Cooper and it looked like it was going to fit, place one bolt on, all good but then tried to fit the rest and it was a no go. Can anyone shine some light on this?
Thanks,
Randy
Thanks,
Randy
You also have to take hub size into consideration, not just 4x100. Mazda has a 4x100 but a smaller hub size so they wont fit. Talk to a wheel shop about the Mini's 4x100 pattern, and our 56.1mm hub size. With anything larger you can use a hubcentric ring (usually) but if it's smaller your only option is to have them machined to the Mini specs...(or find a sharp grinder and do it yourself).
Randy
Originally Posted by Cooperb!
I saw a Honda with MINI S Lites on the other day!
Now that's just sick and wrong
Chris.
Chris.
A Civic must be really ugly too!!
09R56
Nov 16, 2022 10:49 AM
SosoMINI
Nov 22, 2015 03:17 PM
