FS:: Revolution Front Brake Kit - $800 Plus Shipping
Old Apr 23, 2018 | 04:26 PM
miniac78's Avatar
miniac78
Category: Brakes
Price: $800
Location (Region): West
Item Condition: Brand New
Did NOT use these, collected dust on the shelf at my shop. Still in original packaging. NEW!
Revolution Brakes LLC - 07 Cooper JCW Caliper (works with OEM 294mm diameter rotor only), Wilwood FDL four piston calipers.
Brake part - BP-20 Pad Upgrade
Revolution Brakes LLC Rotor 059/060 'Z' rotors slotted only
Attached Thumbnails Revolution Front Brake Kit - 0 Plus Shipping-img_4883.jpg   Revolution Front Brake Kit - 0 Plus Shipping-img_4884.jpg   Revolution Front Brake Kit - 0 Plus Shipping-img_4885.jpg   Revolution Front Brake Kit - 0 Plus Shipping-img_4886.jpg   Revolution Front Brake Kit - 0 Plus Shipping-img_4887.jpg
Old Jul 9, 2018 | 04:17 PM
miniac78's Avatar
miniac78
Still Available
Old Jul 10, 2018 | 01:47 PM
vrum_rum's Avatar
vrum_rum
do you know for certainty that it will work on 2008 R56s? direct bolt-on or additional parts required?
Thanks,
Jeff
Old Jul 11, 2018 | 08:15 AM
Subw00er's Avatar
Subw00er
I have same question for a r52 2006 cooper s.
Old Jul 11, 2018 | 08:42 AM
Whine not Walnuts's Avatar
Whine not Walnuts
This is one of the kits I looked at when I was doing research on my thread for big brake kits. From what I can tell it is a 325 x 32 rotor. That is a little larger in diameter than the Gen2 JCW Brembo, 314, but a little smaller than the Gen2 GP2, 330 mm. The rotor thickness is much thicker than the 22 mm JCW and the 26 mm GP2. The kit does not list the pad or caliper numbers but I am thinking that it is an 8" pad. Also need to verify whether there are dust boots or not and what size the pistons.
Would think a 17" wheel may be required and also would think some good size wheel offsets.
All in all a pretty good looking kit for the money.
Old Jul 11, 2018 | 01:26 PM
Cincy_jro's Avatar
Cincy_jro
I think this is the kit that was designed originally for the R53 JCW (R56) size which would be the 294mm. There was a kit that you could 'swap' the calipers in a JCW R53 and now you have 4 piston calipers with whatever 294mm rotor you wanted... or am I completely wrong here?
https://www.northamericanmotoring.co...iper-kits.html
If I'm right it should fit the standard front brakes on R56 as well but look/perform better?
Old Jul 11, 2018 | 01:32 PM
Cincy_jro's Avatar
Cincy_jro
nevermind. I see the difference. This is the upgraded kit with larger rotors and bracket extensions.
Old Jul 12, 2018 | 04:38 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
wow that includes ate blue too, I wish we could still get that!
miniac78
Sep 5, 2018 03:06 AM
miniac78
Mar 19, 2018 02:45 PM
Enjoytheride
Mar 19, 2015 09:18 AM
bmwbrandon
Mar 8, 2013 07:48 PM
