Revolution Front Brake Kit - $800 Plus Shipping
6 Attachment(s)
Did NOT use these, collected dust on the shelf at my shop. Still in original packaging. NEW!
Revolution Brakes LLC - 07 Cooper JCW Caliper (works with OEM 294mm diameter rotor only), Wilwood FDL four piston calipers. Brake part - BP-20 Pad Upgrade Revolution Brakes LLC Rotor 059/060 'Z' rotors slotted only |
Still Available
do you know for certainty that it will work on 2008 R56s? direct bolt-on or additional parts required?
Thanks, Jeff |
I have same question for a r52 2006 cooper s.
This is one of the kits I looked at when I was doing research on my thread for big brake kits. From what I can tell it is a 325 x 32 rotor. That is a little larger in diameter than the Gen2 JCW Brembo, 314, but a little smaller than the Gen2 GP2, 330 mm. The rotor thickness is much thicker than the 22 mm JCW and the 26 mm GP2. The kit does not list the pad or caliper numbers but I am thinking that it is an 8" pad. Also need to verify whether there are dust boots or not and what size the pistons.
Would think a 17" wheel may be required and also would think some good size wheel offsets. All in all a pretty good looking kit for the money. |
I think this is the kit that was designed originally for the R53 JCW (R56) size which would be the 294mm. There was a kit that you could 'swap' the calipers in a JCW R53 and now you have 4 piston calipers with whatever 294mm rotor you wanted... or am I completely wrong here?
https://www.northamericanmotoring.co...iper-kits.html If I'm right it should fit the standard front brakes on R56 as well but look/perform better? |
nevermind. I see the difference. This is the upgraded kit with larger rotors and bracket extensions.
wow that includes ate blue too, I wish we could still get that!
