Drivetrain Reprogramming ecm???
Old Apr 19, 2018 | 12:55 PM
Tudorfritz's Avatar
Tudorfritz
I’m looking to get my engine control computer reprogrammed on my ‘04 r50. Can anyone recommend a place that can do that?
Old Apr 19, 2018 | 03:16 PM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move to the Gen1 Mod Section, should get some better views there.
Old Apr 24, 2018 | 07:39 AM
fridayxiii's Avatar
fridayxiii
Jan @ RMW is one of the most trusted MINI tuners out there, especially for Gen 1 cars. I don't know what kinda gains you'd get from a NA MINI motor or what mods you've installed, but if you want a tune, Jan is The Man.
Old Apr 24, 2018 | 08:53 AM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
I am intrigued by what kind of race the car is built for. No brake lights, no plexiglass windows, and the cage design. Demolition derby? Dirt track? But why Hoossiers? For demolition derby Mini would be a very bad choice.
Old Apr 24, 2018 | 10:03 AM
Tudorfritz's Avatar
Tudorfritz
thanks I’ll look them up.
Old Apr 24, 2018 | 10:08 AM
Tudorfritz's Avatar
Tudorfritz
I’m going to race it on a 1/4 mile asphalt oval in the 4 cylinder class. Most people run Saturns in that class, I think the Mini should work better then the Saturn. The rules state all glass and lights must be removed and anything flammable from the inside.
Old Apr 24, 2018 | 10:15 AM
pnwR53S's Avatar
pnwR53S
Cool! Thanks for the answer.
Old Apr 27, 2018 | 08:05 AM
downshift1's Avatar
downshift1
Why not just run a standalone ecu? You really don't need any of the functions of the factory unit and it would save you a decent amount of weight in wiring.
Old Apr 27, 2018 | 03:06 PM
Thinker2112's Avatar
Thinker2112
I am very interested in what you did to the engine and transmission.
Old Apr 27, 2018 | 03:24 PM
Tudorfritz's Avatar
Tudorfritz
not exactly sure what you mean by stand alone ecu? The rules state the engine and computer must be stock and un touched. Only thing you can do is cold air intake and remove converter and muffler. So I know pretty much everyone reprograms there ecu because there is really no way to tell if it’s been messed with.
Old Apr 27, 2018 | 03:30 PM
Tudorfritz's Avatar
Tudorfritz
right now all I did was cut the converter and muffler off and have a straight pipe running out to the side of the car. I also got a cheap universal cold air intake off eBay. The rules state the motor has to be stock or oem parts. The only real thing they check once in a while is compression, total weight, left side weight. So if there are a few things I could do to tweek the motor I’m all for it.
Old Apr 27, 2018 | 03:39 PM
downshift1's Avatar
downshift1
A stand alone would be be against your class rules then as it would be an aftermarket unit.
Old May 7, 2018 | 07:58 AM
Thinker2112
You can shave a few more pounds (probably) if you can get your hands on a set of Hole-ies for wheels. The stock MINI 7 hole 15x5.5 wheels are 12 pounds each.
Old May 14, 2018 | 12:05 PM
Tudorfritz's Avatar
Tudorfritz
rules say you have to run wheel studs and 1” lug nuts. Those lug nuts would never fit in the lug hole of a aluminum wheel.
Old May 18, 2018 | 08:32 AM
Thinker2112
You might be able to get more power if you get your hands on some JCW or S fuel injectors, you will still need to get a tune for them and as stated before, Jan at RMW is the guy you want to talk to.
I suppose on the wheel front, you could swap over to studs and lug nuts and drill out the Holies.
MacBones
Aug 10, 2008 06:36 AM
Brihyanna
MINI5280
Feb 26, 2007 05:08 AM
JPMM
Sep 8, 2006 01:01 PM
joesantoyo78757
Jul 28, 2004 11:34 AM
Russiaville
Dec 6, 2003 06:21 PM
