R56 09 MCS Cooling Fan Battery Drain
Volunteered to help my daughter resolve some issues with her 09 MCS. The car likes to drain the battery completely on an intermittent basis. Its already trashed a couple of batteries. A mini specialist in Phoenix had told her he thought the cooling fan was the issue as she said on occasion the fan would run and not shut down after the car was driven and hot. I was able to get the car good and hot the other day and the fan ran for almost 20 minutes after shutdown before I tapped on the K22 relay which shut the fan down. Other forum posts have indicated that the cooling fan should time out and shut down after a max run time of 15 minutes. Can anyone verify this is correct.? So at this point I'm going to replace the cooling fan and the k21/22 relays for the fan. I also checked for current draw when the car was acting normal and fully asleep and measured around 50 milliamps so at this point I haven't found any excessive parasitic loads. Has anyone experienced issues like this with R56 MINI's? Anything else I should be looking for? My first experience working on MINI's, I'll never complain about working on my old F150 again.
Sometimes you will see (or smell) the coolant, but not always. In my case, the leak was small enough to evaporate on the engine, but large enough to cause the sensor to read the temp/thermo incorrectly (causing the fans run excessively, and drain your batt).
And my R56 the same no coolent level discrepancies 1st replaced thermostat sensor and it went away the fan stopped running after turning the car off, few days later check engine light and the coad.
My tech $645 to replace it.
Ben
Ben
Ben what work did your tech have to do to clear the fault code? No ibs on this car so I don't believe battery registration is required....This car also has ABS/SRS lights on....anyone have success clearing these with c310+ scanner?
No additional work was done.
Ben
Thanks for the heads up Eddie07S....I have been able to hear that pump run after the car has been warmed up. Guess that doesn't necessarily mean that it is functioning properly. I think at this point I'm going to replace the fan, both relays, and the coolant temp sensor. I decided I didn't want to do the thermostat unless absolutely necessary. We'll go from there. The car also has a leaking front crank seal. I told my daughter she needed to go to the dealer and have that done. If it was mine I'd probably try using the pvc seal driver method. No sure how long I want this fine piece of German engineering stuck in my garage.
jeffl
Aug 30, 2014 03:34 PM
JPMM
Oct 10, 2011 02:58 AM
Dan1967
Sep 19, 2010 04:36 PM
ilscoobydooll
Jun 4, 2007 02:47 PM
