R52 Third brake light replacement
Old Mar 29, 2018 | 06:27 PM
DaGriz's Avatar
DaGriz
I assume that t nlugs? If broke while replacing the trim
Old Mar 29, 2018 | 09:51 PM
PokerMunkee's Avatar
PokerMunkee
I'm interested too. Mine has a crack What did you buy to replace the trim? Mines I'm bad shape. I read somewhere you can spend $40 to $200. What are the options?.
Old Mar 30, 2018 | 04:02 AM
Whine not Walnuts's Avatar
Whine not Walnuts
I saved the money on buying the trim and just did a DIY, perhaps $40 vs $400+. On the light, would assume it plugs in but might have to remove the trim again.
https://www.northamericanmotoring.co...ng-away-3.html
Old Mar 31, 2018 | 04:33 PM
DaGriz's Avatar
DaGriz
Ok. Got the new light and makes the exchange obvious.
I’m still not sure how much good these trim pieces do with water intrusion. They seem more garnish than function
DaGriz's Avatar
DaGriz
I’ll try your solution with old pieces.
Old Apr 3, 2018 | 02:13 PM
Was just going to send you to that thread, watch when you take it off sometimes the litte screws are rusted and the torx head screws can break. Yep, you can access it from between the trim. And then there is a little plug in the middle.
I have the rare clear version here and you can see the plug and how it looks removed. 63256961015 Those little holes are where the screws come through.
https://www.ecstuning.com/News/MINI_...006_2007_2008/
thesilkiest
R57 :: Cabrio Talk (2009+)
23
Mar 11, 2025 06:19 AM
banyan
Jul 10, 2016 05:03 PM
banyan
Jan 6, 2016 01:25 PM
Spiderwolf
Sep 6, 2008 09:54 PM
mini_racer
May 1, 2008 09:49 PM
