Suspension Raise Front end slightly
I need to bring my front end up between 1/4 and 1/2 inch to avoid some very minor rubbing issues. I’ve thought about the under strut reinforcement plates, but the ones I found are 3.5mm.
Would a camber plate like Ireland or Eibach do it?
I’m on Koni FSDs and NM alpha springs.
Which under struts have you found, as I haven't seen any for the r56?
If they are cheap, is a sandwich an option?
But I'd be tempted to spend on fully adjustable plates, rather than just the fixed ones
Last edited by blue al; Mar 26, 2018 at 08:46 PM. Reason: Of course camber might be a win, win
Lexan has an extremely high compressive strength yet is is easy to cut and shape. It can be drilled as well with entrant cracks not be an issue. You can buy sheets at any home improvement type store and it also can be glued together with various types of adhesives as well as contact cement.
If you install IE fixed camber plates, it will raise the front about 1/4", as well as giving you more camber. Sounds like a reasonable way to get where you want to go, for about $200 in parts.
These plates use the factory upper strut mounts, so there wont be any harshness or excessive noise.
Have fun,
Mike
Have fun,
Mike
IQRaceworks
Suspension
14
Mar 1, 2012 08:09 AM
fozworth
Suspension
20
Mar 14, 2007 05:52 AM
Azzurri
Jun 9, 2003 02:34 PM
