Suspension Raise Front end slightly
Old Mar 26, 2018 | 07:09 PM
keithmcgreggor's Avatar
keithmcgreggor
I need to bring my front end up between 1/4 and 1/2 inch to avoid some very minor rubbing issues. I’ve thought about the under strut reinforcement plates, but the ones I found are 3.5mm.
Would a camber plate like Ireland or Eibach do it?
I’m on Koni FSDs and NM alpha springs.
Old Mar 26, 2018 | 08:43 PM
blue al's Avatar
blue al
Which under struts have you found, as I haven't seen any for the r56?
If they are cheap, is a sandwich an option?
But I'd be tempted to spend on fully adjustable plates, rather than just the fixed ones
Last edited by blue al; Mar 26, 2018 at 08:46 PM. Reason: Of course camber might be a win, win
Old Mar 27, 2018 | 03:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Maybe consider different springs? You are going to want to raise the rear the same amount, or your handling will be wonky.
Old Mar 27, 2018 | 05:57 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Lexan has an extremely high compressive strength yet is is easy to cut and shape. It can be drilled as well with entrant cracks not be an issue. You can buy sheets at any home improvement type store and it also can be glued together with various types of adhesives as well as contact cement.
Old Apr 11, 2018 | 05:34 PM
keithmcgreggor
Opted for Bilstein PSS10s and Vorschlag camber plates ... once the parts get here, I'll get it truly dialed in.
Old Apr 11, 2018 | 10:43 PM
blue al's Avatar
blue al
I'm very happy with my bilstiens pss10 B16
Although you may find when you come to fit them that you need to lower the rears a little more than the fronts to avoid excessive rake
Old Apr 12, 2018 | 01:46 PM
blue al's Avatar
blue al
8mm taken from rear
Fronts left at maximum lift
Might take more out over time
Old Apr 12, 2018 | 08:48 PM
mbwicz's Avatar
mbwicz
If you install IE fixed camber plates, it will raise the front about 1/4", as well as giving you more camber. Sounds like a reasonable way to get where you want to go, for about $200 in parts.
These plates use the factory upper strut mounts, so there wont be any harshness or excessive noise.
Have fun,
Mike
IQRaceworks
Suspension
14
Mar 1, 2012 08:09 AM
L0KI
Aug 16, 2010 08:15 PM
fozworth
Suspension
20
Mar 14, 2007 05:52 AM
Azzurri
Jun 9, 2003 02:34 PM
