R56 rear suspension replacement help
Old Mar 26, 2018 | 09:14 AM
antonio_zeus's Avatar
antonio_zeus
Hello Mini Experts,
I need help finding the parts for a job I need to do. I have a 2008 Mini Cooper R56 (Base Hatchback, SOHC engine)
JOB: Replace rear suspension/struts and maybe rear tie rods as well.
PARTS: what parts do I need for these jobs?
Any help with part numbers or links to websites are extremely appreciated.
Thank you.
Old Mar 26, 2018 | 11:06 AM
mabbonizio's Avatar
mabbonizio
Try ECS tuning or FCP Euro
Old Mar 26, 2018 | 11:28 AM
Hello,
I can help.
I would do the powerflex bushings, do it once and never worry again. Here are all the bushings, black series is for race, most people just use "performnace" versions/ they are currently on sale with 10% off.
https://www.ecstuning.com/News/MINI_...9_S_JCW_23542/
https://www.northamericanmotoring.co...int-knock.html
DIY> https://www.northamericanmotoring.co...-cooper-s.html
Front and Rear shocks: Most people either go with Bilstein or Koni, for just normal use the B4 Bilstein shock are good.
https://www.ecstuning.com/Mini-2008-...ension/Shocks/
Old Mar 26, 2018 | 12:05 PM
BigBoost's Avatar
BigBoost
Just re-did my stuff all away around ! Was about 2000ish
All new
Koni sports
Eibach spring
Oem front mounts
Oem upper spring plate
Oem rear dust cover
Oem guide support rear
Oem spring plate
Oem spring guides
Power flex black/series
Rear shock tops
Performance Polyurethane Bump Stop Set
Sway bar link bushing
Rear trailing arm bushing
Attached Thumbnails rear suspension replacement help-e7839925-9d07-4d27-a523-78cab8fc5f61.jpeg
Old Mar 26, 2018 | 01:34 PM
Whine not Walnuts's Avatar
Whine not Walnuts
You will hear people talking about the struts being shot around 50,000 miles. What, many will say, I have 75,000 on mine and they still work good? Well actually they don't, they just think they do. I had 55,000 on mine, there was no rebound and I could just about push the piston rod down by blowing on it.
Old Mar 28, 2018 | 07:50 AM
I really like that picture
All new
Koni sports
Eibach spring
Oem front mounts
Oem rear dust cover
Oem spring plate
Oem spring guides
Rear shock tops
Old Mar 28, 2018 | 10:27 AM
MiniCooper_S's Avatar
MiniCooper_S
Hey bigboost
All new
Koni sports
Eibach spring
Oem front mounts
Oem rear dust cover
Oem spring plate
Oem spring guides
Rear shock tops
How low is it with that setup and how is the ride quality? Also what spring rates? I’m thinking of ditching my bc racing coilovers and going with the Koni/Eibach setup on my 200mi+ a day daily driver. It seems like I spend more time watching out for pot holes than actually driving.
Old Mar 28, 2018 | 10:37 AM
MiniCooper_S
Originally Posted by antonio_zeus
Hello Mini Experts,
Thank you.
Are you looking for a performance upgrade or just making a repair to a daily driver?
Old Mar 28, 2018 | 02:46 PM
antonio_zeus
Just looking to repair my daily driver. So specific parts would be awesome, as I have a local guy do the work, and I simply buy the parts. I just want to make sure I get what I need.
Old Mar 28, 2018 | 04:18 PM
MiniCooper_S
grab a set of these Bilstein b4 from ECS.
might as well do all four while you’re at it.
surfacenormal
Jun 19, 2014 02:34 PM
minsane
Suspension
Jan 27, 2011 02:40 PM
MiniGB06
Suspension
Apr 16, 2009 10:20 PM
02Doooce
Suspension
Aug 26, 2008 08:42 AM
