R56 How many miles on your R56 automatic aisin transmssion?
That would be the death knell.. no way I'd touch it at this stage.
2014 Clubman S with 63k. It was all stock until 52k then went Manic stage 2. No issues. Just put on a 42mm Turbo, no issues. Waiting on my ECU back with Stage 3...praying. I asked Mario a few times if the auto had enough ***** to handle all this. He stated he had several people running upwards of 300hp on the auto and racing them with no issue. I will probably do my tranny fluids more routinely just to keep it healthy and happy. So far though I've never seen the trans fluid raise over 180 degrees after some spirited driving/racing.
Wow! Your tranny must've been built on a wednesday haha. Mine has ~46k and has had a ~2.5 qt drain fill with royal purple every 10k since birth. Also stage 2 manic tune to keep the temps down (no problems with the increase in power)
Hey 4mikebruns, How do you do to see the temperature of the transmission oil? are you using an app?
2007 cooper s - transmission failure at 170k. First it started slamming hard into 4th gear, then eventually all gears above 3 started slipping. Replaced with a 65k mile unit which got a full fluid and filter change before installation. 65k fluid looked good, so I would say 80k changes would be optimal and safe.
That's very optimistic of you. My 2008 S just blew a valve in cylinder 3 at ~150k miles. Well I'm guessing it's the valve. That cylinder had zero compression. I haven't pulled the head yet.
My tranny is still functioning despite never having changed the fluid. No leaks either. It did start to downshift hard into 1st occasionally.
That being said, I hesitate to even change the head OR the engine because I expect the tranny will die soon. And I don't know if I should/could trust any used mini tranny. A remanufactured tranny exceeds the value of the car at this stage... Bummer.
Wait wait wait... You put a used tranny in a car with 170k miles on it?...Original engine???
GSequoia
Feb 20, 2026 10:55 PM
clutchless
How to
Mar 24, 2022 10:47 AM
rus19
Mar 29, 2015 07:30 AM
06coopah
May 16, 2013 02:52 PM
